My Superwinch hubs and 4.9 front end is for sale.
eurosonic
Since Im going SAS I wont be needing these.
The hubs are Superwinch which are some of the best on the market. They are in excellent working condition. I believe these are discontinued.
The front end is a 4.9 from a Sport. Selling it complete with all the correct half-shafts and new seals that I installed about 4K miles ago. The way it is right now would make it strictly a bolt in solution.
$300 for everything.
jeep-N-montero
Was that the part time or full time case in the Sport? I am definitely going to take the hubs if they are still up for grabs, undecided on the diff. Is there anything specific you may be in need of for a trade?
eurosonic
I believe its full time. It worked exactly the same as the original.
I need a dana 300 transfer case.
plh
Any idea on shipping the front axle complete assembly to zip 53209 - business address with shipping dock & fork truck. (I don't need the superwinch hubs)
plh
No worries, took a look on car-part and there are several close to me. Did you pull the 4.9 rear from that truck also? If you did, entire 3rd member w/Locker? Wheel to wheel? or only Ring and Pinion. Assume the '02 Sport is also a 9.5"....
eurosonic
I pulled a non locking the third member then swapped over the gears to mine.
Clemtiger84
