What kind of "shore power" type plug for #6 cable into tongue box from solar panel(s)
lesabret
I am using a Morningstar Prostar-30 solar controller and want to use #6 cable for the run to a portable solar panel, possibly multiple panels.
Want to have 2 lengths of approx. 25' each to allow flexibility of hooking one or both lengths up to have up to 50' of run from panel(s) to tongue box, thus desire for #6 cabling.
Looking for a bulkhead connector for tongue box wall to plug the #6 cable from panels into on the outside of the box and have #6 wiring from connector backside to controller inside the box.
I've only seen plug and play connectors for portable solar setups using smaller gauge cabling ie. #10.
Anyone know of a connector (waterproof of course) that would work in my scenario?
Also, can the typical MC4 connectors used in solar setups handle #6 gauge or is there a better connector to use for the inline connection of the two 25' sections?
Thanks for any tips.
AndrewP
Watt(sic) is the output of your solar panel?
I ask because if it's a single panel of 100 watts or so, the amps will rarely exceed 5-6, and so voltage losses will be minimal. If you put your charge controller near your battery this will also help to minimize voltage drop into the battery. So let's say you have near 20 volts coming from your panel and you have a full volt loss at full power into your controller-you can still easily fully charge your batteries to spec.
So the out put of your panel and the distance will determine the size wire you need to run, but off the cuff, I would say 10ga or even 12ga is plenty and much easier to hook up. Plus this is low voltage wiring anyway and strict waterproofing is likely not necessary. The other problem with 6ga wiring is the bulk and stiffness of it.
Anyway if you know your amperage in full sun and you know the distance, you can look up voltage losses on a chart, or use a calculator like this one:
http://www.supercircuits.com/resources/tools/voltage-drop-calculator
For quick and dirty assuming 10ga is enough, outdoor extension cords work great and are widely available cheap. Cut the ends off, install whatever connectors you like and you are good to go. I put my system together with Anderson Power Poles.
Using an example of a normal portable type solar panel of 100watts: assuming the voltage output is 20 or so and at full power operates at 7 amps, you'll have about a 0.4 volt drop over a 25 foot run of 10 gauge wire. So you will have an insignificant voltage drop from 20 to 19.6 and your controller will still operate normally.
dwh
Tail-End Charlie
That's true for an MPPT controller. But a PWM controller is just a very fast computer controlled switch. Doesn't matter where in the line you put a switch.
Again, MPPT vs. PWM.
With a PWM charge controller, the PV module won't ever put out its full Vmp voltage. Even if Vmp is 20v, the panel will be operating at the voltage of the battery. So if the battery is at 13v, then the panel will be operating at 13v. Using 20v in the voltage drop calcs would result in a number that's way off.
With MPPT the panel will operate at Vmp, but the voltage drop isn't going to matter much, since the Vmp will be way higher than the voltage on the battery side anyway.
But I agree that #6 would be way overkill for a 50' run from a 100w panel. #10 or even #12 would get it done. Voltage drop doesn't much matter when battery charging. (It does matter quite a bit when running loads FROM a battery.) Voltage drop is a function of load, and by the time the battery gets full, the load will be almost nothing, and so will the voltage drop. Going oversize on the wire just to shave a few minutes off a process that takes hours anyway isn't going to have any major benefit.
AndrewP
It sounds like we agree! The Prostar 30 (mentioned by the original poster) is an MPPT controller(edit-not sure if this one is MPPT or not, but id doesn't matter), though I believe this is also way overkill for this particular application. It's just common sense and good practice to keep the run from the charge controller to the battery as short as possible.
wirenut
Anderson power pole connectors are available to fit #6 wire. They would be a good option for your plug. You can use the MC4 connectors if you like. It may be tight getting a #6 in them. I'm pretty sure #8 would fit but I've never tried #6.
dwh
Tail-End Charlie
Pretty sure the Morningstar TriStars are MPPT and the ProStars are PWM.
1stDeuce
DWH, you're usually spot on with your advice, but in this case, your are very incorrect. No matter what controller you use, it needs to be close to the battery so it is "controlling" the battery to it's set voltage, and not some lower voltage due to voltage drop in the wiring. (Viewing the PWM controller as a "fast switch" is actually pretty inaccurate in this case, as it really does regulate the output voltage, not just connect or disconnect.)
For example, if your charge controller (either PWM or MPPT!) is controlling to 14.4v, and you have it mounted to the panel with 25' of wire between it and the battery, then your battery isn't going to see 14.4v, but rather 14.4 minus the voltage drop in whatever wiring you run. Even with fairly oversize wire, as the OP wants to use, there is still SOME voltage drop, and your battery isn't going to charge at the intended voltage.
Let's say you have .5v of drop due to the distance of wire that you must run, and you put the controller right at the battery. It is likely that your panels are going to put out ~16-17v or more, so even with significant voltage drop in the wire, your charge controller still has to regulate the supplied voltage down to 14.4v, and your battery gets 14.4v and charges quickly and fully. If you move the controller to the panel instead, it still controls to 14.4v, but your battery will only sees 13.9v due to the .5v voltage drop in the wiring. At 13.9v, charging your battery to 100% will take much longer! With solar, you're limited on charge time, so you want charge voltage to be correct so you get to 100% in the shortest time possible! From an engineer's perspective, that ALWAYS means charge controller AT the battery, AND temperature compensated!
To the OP, I might suggest the SB50 Anderson connector for quick disconnect if you really want to run 6ga wire. But as others have said, using 6 AWG wire may be a LOT of overkill, unless you're putting the controller at the panel, in which case you're STILL NOT DOING IT RIGHT. :)
If you put the charge controller at the battery, then you can easily do with much more inexpensive and easy to handle 12ga or 10ga zip wire. Anderson "power pole" type connectors would excellent with up to 12 AWG wire. You could probably cram some 10 AWG into them with a little beer and muscle. :)
1stDeuce
The Morningstar Prostar is not an MPPT controller, but it should work great for you since you're planning to mount it in or very near the battery box.
For 120w of panel or less, you really should be fine with 10 or even 12ga wire unless you really want to max out the system, or run longer than 50'. I like the extension cord idea for ease of storage, but zip wire would take up even less room...
As for connectors, for 12v, there's really no need for them to be really "waterproof" I wouldn't think... If they were, like with MC4 connectors, you'd want to be sure to keep a dummy plugged in when you were unhooked, but I think the open Andersen style connectors should work fine, though they might need an occasional cleaning up. Or just put the connector inside the box too and you're good to go.
If you're running multiple panels, keep each one on it's own extension cord, and "Y" them together near the charge controller. That will also keep the voltage drop to a minimum by keeping the current on each wire to a minimum. If you REALLY need the length, then put the Y nearer the panels. You'll have a little voltage drop, but before the charge controller, so it's much less critical. (Even at 50', with 12AWG, you'd have about .5v of drop. But nominal panel output is more like 17v, so your charge controller will still have to drop that to 14.4 for charging... even a "horrible" voltage drop of .5v is workable if you have the charge controller at the battery.)
C
dwh
Tail-End Charlie
"Pulse-width modulation (PWM), or pulse-duration modulation (PDM), is a technique used to encode a message into a pulsing signal. It is a type of modulation. Although this modulation technique can be used to encode information for transmission, its main use is to allow the control of the power supplied to electrical devices, especially to inertial loads such as motors. In addition, PWM is one of the two principal algorithms used in photovoltaic solar battery chargers,[1] the other being MPPT.
The average value of voltage (and current) fed to the load is controlled by turning the switch between supply and load on and off at a fast rate. The longer the switch is on compared to the off periods, the higher the total power supplied to the load.
" [emphasis added - dwh]
http://en.wikipedia.org/wiki/Pulse-width_modulation
"Fast switching" is the EXACT definition of what PWM does. Fast switching is HOW it regulates the voltage and amperage on the charging loop.
It's not "pretty inaccurate". It is absolutely, certainly, totally and completely 100% precisely accurate. :)
It is a switch. It regulates by switching on and off at various speeds. It DOES NOT MATTER where in the circuit you put that switch.
This is one of the most common errors I see on the net. Been seeing it (and correcting it) for years. I blame the solar forums (and years ago I was offered a slot to be a moderator on the NAWS forum, so I've seen how it happens).
I've said it before, and I'll keep saying it: Voltage drop is A FUNCTION OF LOAD.
Repeat: A FUNCTION OF LOAD.
When the load on the wire is large, then you'll have large voltage drop. But when the load on the wire is small, then you'll have small voltage drop.
As the battery approaches full, the amps flowing - and thus the LOAD on the the wire will reduce - and thus the VOLTAGE DROP will reduce. By the time the battery is above 90% full, there will be almost no amps flowing, and there WILL BE NO SIGNIFICANT VOLTAGE DROP because there is not enough LOAD on the wire to cause any noticeable voltage drop..
You can "calculate" X voltage drop at Y load, but it's misleading because when the battery is almost full, the load might only be 1 or 2 amps. So recalculate the voltage drop using the ACTUAL load. Then do it again for .5a, .25a, etc.
Thus...NO! Voltage drop WILL NOT cause a battery be "Xv low".
(Voltage drop through a wire that is...voltage drop through a diode is a different story.)
It will NOT be, as you say, "14.4 minus the voltage drop", because "there ain't no voltage drop".
That is NOT how it works...NOT AT ALL.
With PWM, there is a single charging loop. ONE BIG LOOP (a.k.a., circuit). That loop includes the battery, the wiring, and the PV module. The BATTERY will regulate the voltage on that charging loop - until the battery voltage rises to the charge controller's set point, at which time the charge controller will take over and regulate the voltage on the loop by fast switching to hold the loop voltage at the set point.
UNTIL the battery voltage - and thus, the voltage of the ENTIRE LOOP - rises to say, 14.4v, the PWM charge controller will be operating basically "wide open" (much more duty cycle time spent "on" than time spent "off").
Because of this, the PV module will NOT be operating (EVER) at Vmp. It will be operating at whatever voltage the battery is at.
What is the voltage drop between the charge controller and the battery? Effectively - none. Big wire, small wire, heavy load, small load. VOLTAGE DROP IS EFFECTIVELY NONE.
Because the charge controller and the wire and the PV module and the battery is all part of the "one big loop" and the ENTIRE loop WILL BE at whatever voltage the battery is at.
Thus...MPPT.
MPPT *splits* the charging loop from one big loop, into two loops - one on the solar side, and one on the battery side. It then uses the MPPT circuit to regulate the voltage on the solar side, allowing the PV module to operate at whatever voltage gets the Max Power. Most sample the circuit every 60 seconds and adjust the load as needed to maintain the voltage of that loop at whatever it needs to be to get Vmp under current conditions.
It then takes that higher voltage, and runs it through a buck converter to lower the voltage (which also causes the handy side effect of increasing the amperage), then feeds the output from the buck converter (usually through a PWM circuit) to the battery.
Unlike PWM, with MPPT the PV module actually DOES operate at Vmp. This gets you more total watts from the PV module. Reducing the voltage from Vmp to battery voltage, increases the amps to the battery. It's a win/win. But it costs more for the MPPT controller, AND the lower the battery voltage, the more benefit you get from the amp "boost" of lowering the voltage. If the battery is never below 50%, and the PV is less than 200w, then it's generally not worth it to pay the extra for the MPPT controller.
So with an MPPT controller, which has TWO LOOPS, then yes, it's best to make the battery charging loop as short and thick as possible. But that's NOT the case with PWM, which is just a switch in the middle of ONE BIG LOOP.
(And yes, I am aware that HandyBob screwed up on that one. But he's using MPPT, and he's used to doling out generalized "best practice" advice to a bunch of knuckleheads in Quartzite. So it's an understandable, minor and completely forgivable error on his part that he simply lumps all charge controllers together and makes the same recommendations for both. After all, even through it isn't needed, it won't actually HURT anything to put a PWM charge controller as close as possible to the battery and use bigger wire on a short section of that one big loop. Hell, it might even gain someone a fraction of a percentage point in extra amp*hours, so what the hey...go for it Bob.)
People have a picture in their mind, of "Point A to Point B". That's totally wrong. It's a circuit; a loop. So the correct picture is "Point A all the way around and back to Point A".
So what is the ACTUAL EFFECT of this theoretical voltage drop when charging a battery? The increased resistance of too small a wire, will cause it to take longer for the battery to reach 14.4v. It WILL NOT prevent the battery from reaching 14.4v, but it WILL take longer to get there.
And this is why you see this error all over the solar forums. Those guys are trying to squeeze every watt out of a LIMITED TIME WINDOW of "good sun" by VERY CAREFULLY balancing the variables of <PV output|wire size|battery size|time>. So they keep repeating the Holy Mantra of, "voltage drop = bad" and "max allowable voltage drop = 3%".
But that's NOT because the battery won't get to full charge, it's because it won't get to full charge IN THE LIMITED TIME WINDOW.
Another reason this error is so common, is because most people never realize that voltage drop behaves ONE WAY when running loads FROM a battery (voltage drop increases as battery voltage goes down), and behaves THE OPPOSITE WAY when feeding power TO a battery to charge it (voltage drop decreases as battery voltage goes up).
(And don't mind the caps. I just use them for a quick and dirty emphasis - I'm NOT actually yelling at anyone. :D )
(You now owe me: One Cold One. :ylsmoke: )
AndrewP
OK - LOL
I'd still put the charge controller close to the battery if nothing else to take advantage of the temperature compensation. And, there is no downside.
For the OP, if you're just using 1 panel why do you want to use a 30 amp charge controller? A 10 amp charge controller will be plenty and you'll save a few $$.
lesabret
OP here,
As usual, I didn't provide enough clarification in my initial thread question.
I'm having a teardrop trailer built with the tongue box housing the power supply electronics.
There is a Magnum Energy 1000 watt inverter/charger with GFCI outlet, 15A shore power, 2 group 31 AGM sealed batteries @ 100 AH ea. for 200 AH total or 100 AH @ 50% discharge.
The Prostar controller will be housed with the inverter/charger and other components and will connected to the battery bank by less than 2 ft. of wiring.
I was thinking of a pair of solar panels (not yet purchased nor brand/source determined) in the range of 140 - 150 watts each. Thought was to hinge them together in a portable "suitcase" type arrangement and run them in parallel so if one became impaired, the other could still provide charging power.
I reside in the Midwest and clouds rule. My thinking around the overkill as far as up-gaging the cable to #6 was to minimize voltage drop, concerned not so much with voltage seen at controller/battery bank, but to let as much current flow over the shortest amount of time, since the amount of useable sun power is less than that of sunny Southern California or Utah, etc.
Reading previous discussions on the topic, led me to believe that allowing more current flow via larger cabling would facilitate shorter charging time via the solar panels. I was thinking the situation would be similar to the discussions around tow vehicle charging with #10 wiring via typical 7 pin connection and how the consensus seemed to be that charging would take place but would be slow and require driving for long periods of time. Typical solutions to this seemed to be to up-gage wire to #8 and run directly from TV battery to trailer.
Am I mistaken in thinking charging from solar panel(s) would be the same and to achieve same charge over shorter time period requires larger cable? If I am loopy in my reasoning and something like #10 from the solar panels would charge just as quickly as #6, then I certainly would be willing to downsize the wire gage both for cost and ease of handling the cabling.
My original question was about an available weatherproof bulkhead receptacle to plug the solar panel cabling into that would take #6 wire (both mating plug & receptacle). If shorter charging times can achieved with smaller gage wiring, then I could use a recommendation on whatever weatherproof receptacle is suitable.
Thank you to all who have replied, I really do appreciate it.
1stDeuce
Your thinking about voltage drop being bad is correct, but the application is different, so it's relative.
When charging from a tow vehicle, you still want the house battery to charge at 14.4v (or whatever the TV is charging at) but to get that full voltage to the trailer with ~30A or more of current and minimal voltage drop, you need HUGE cable. Still, due to connectors and just plain length, the House battery is going to charge at a slightly lower voltage, but if you use big enough wire, the drop will be minimal for normal amperage flow. As the charge gets completed, and current drops, voltage at the house battery will go up slighty until they are both about equal at zero current flow.
But for a solar setup, your panels are outputting more like 17v, so if you get some voltage drop in the wiring before the charge controller, the house battery will STILL get a full 14.4v. Therefore the drop before the charge controller is not as relevant to proper charging. Technically, you are "wasting" a little bit of power through the resistive loss, and the fact that your panel isn't operating at optimum as it would with an MPPT controller, but the battery is still charging at 14.4v, and that is the important part!
Make sense?
BTW, DWH and I are sorry to disagree on your thread. His wordy description of PWM control isn't wrong at all, but it is still "simplistic" because he's viewing the control in a one loop sense, ie a very small time frame, instead of how it behaves when used as a voltage regulator in a system with wiring.
I still think his idea that voltage is the same no matter where you are in the system is only correct if there is zero current flow, in which case your solar setup isn't doing anything anyway. When under charge, there is current flow, and with current flow comes voltage drop... Anyway, we've taken our discussion offline, and I'm about to conduct an experiment with about 30' of wire to figure out which of us is not thinking correctly.
Chris
dwh
Tail-End Charlie
Right, and it is an issue, and it gets worse as the solar array size gets larger. If you were only going to use 100w of solar, then our previous recommendations of #10 or even #12 would be correct. But if you are going to use 300w of solar, that's a big difference. Approx 25a of output. Sending THAT through a 100' loop of #10 would certainly slow down the charging process enough to be significant. So for a 300w array, I'd say you were on the right track, and using #6 for a 100' loop would be quite reasonable.
Well again, it's a question of size. A solar array that puts out 10a, 15a, or even 25a, is one thing, Taking the output of an alternator which would potentially supply 100a or more and choking it off with small wire is something else. Though, the reason the factory only uses #10 is because the normal battery for a trailer would be a battery to operate the brakes during a breakaway. It's not a huge battery, and even with the #10 slowing down the charging process, it will still ultimately get fully charged. Actually, since it would be used only in an emergency, it would be basically "kept topped off", which the #10 would certainly be adequate for.
lesabret
OP again,
Thanks for the follow-up answers after I posted my "clarification".
I'm glad that I wasn't totally insane about thinking larger cable = good when using 250-300 watts of panel power.
Though I am somewhat concerned about the ease of manipulating 100' or more of #6 cabling and am now considering moving down to #8, mainly for ease of handling. It may lengthen charging times, but the more I think about what a PITA #6 would be, I hope #8 will still get the job done in a reasonable timeframe.
However, while the discussion on wire size was great, I still need a source for a bulkhead type weatherproof connector & plug set to attach the #6 or #8 cabling to in order to get the charge into the tongue box and to the controller. Does anyone know of sources for such plugs and receptacles that will accept the heavier gage wire?
Sorry for the emphasis on the preceding paragraph. This will be my first foray into solar panels, and associated connectors and plugs for the cabling and I am under the impression that the commonly used connectors like that made by Zamp, are made to accept smaller wire such as #12 or #10. At least the picture of their solar plug receptacle on their website looks like smaller gage wire.
Any further tips are very much appreciated and I do want to say thank you again to the folks who have taken the time and patience to post replies to my questions in this thread.
dwh
Tail-End Charlie
I think you'd do better to worry about manhandling 300w of solar panels rather than worrying about manhandling the wire.
But here:
http://www.powerwerx.com/
They've got the powerpole connectors, and down the page under powerpole accessories, the bulkhead fittings.
zhukoveli
