Additional cargo tie downs for a 14' Rubi Unlimited
sonofmdlbldr
Hey All,
Recently removed my rear seat on my 14' Rubicon Unlimited. I'd like to put additional tie downs in the back.
Does anyone out there make tie downs that I can place under the existing floor bolts (the ones used that connect the rear seat to the floor). I'm wondering if there are "washer" type tie downs I can just pop onto the existing floor bolts in the rear.
Thanks for the help!
A
AngryRedBird
Guest
The First thing that comes to mind is head over to your local marine/boat store or even the RV camping shops.. As seen here:
http://www.easternmarine.com/Tie-Down-Rings-Hooks-Eye-Bolts/
Also, having worked for a moving company.. They took one of the smaller panel vans and put 2 strands of a track type system into the bed.. which allows for hooked ties downs and these hooks can be adjust and placed into different holes along these tracks. I've done something similar to our jeep.. but It's attached to my security cover suspended above the cargo area..
HRPINDC
Yeah, not the cheapest option. But I liked that they weren't just crimped shut, like the others I found. I imagine that would be the weak spot. Plus I only needed a few, so I spent an extra $12 perhaps. I can treat myself to the good stuff once in a while......
DEFENDERBEAM
strategic command
try McMaster Carr.
If they don't have what you're looking for, it might not exist? haha.
It's my go to place for metric, and non-typical hardware store hardware.
DanoWall
