Receiver mounted MFC carrier
precision powder
Backwoods Explorer
So I have been looking for a good way to carry extra fuel on the outside of my jeep without a roof rack or wanting to mount 50 pound cans on my spare tire and I couldn't find anything that I would be happy with. I looked at the normal receiver cargo basket and it was just too wide and would not be a very secure mount at all. I wanted something that was rock solid, would hold multiple cans for extended trips where I wouldnt see gas stations for days, would allow me to lock the cans to the mount so someone could not run off with them, and something that was removable and was not a destructive mod that included making changes to the vehicle its self.
This is what I have come up with so far. I have a few things to finish up still, mainly I need to powder coat (zinc primed base textured black top coat) it still and I need to finish the bar system that covers the can lids so they cannot be taken off by someone without the key.
I used 1" x 1" tubing .125 wall, .25" x 1.25" flat bar, 2" angle iron .25 wall, and 2" x 2" tubing .125 wall. Everything was welded on all sides for added durability but also so there was no place water could potentially get inside. I knew building this that shaking and moving would be a killer if it was allowed to rattle around, receivers are not a perfect fit. So I added 2 tabs to attach turn buckles to the receiver so I could tighten it down and prevent any movement at all. The result was zero shake or give. Any attempt to make it do so actually move the entire Jeep in the process. There is not even the slightest wiggle now. I also ran the 2" tube straight out the back of the receiver within an inch of the muffler so when I get around to making my new bumper I can drill a new hole sit close and still provide the clearance needed.
Happens to be the perfect height to use a siphon to refuel with as well.
Now I am sure a lot of people may think it ruins departure angle, and yes it does but this weekend proved that even with that much hanging off the back I still am better off the full size trucks. I try to avoid places on these kinds of trips I would experience those kinds of departures anyway or I just find a different route. I only hit it once on a very nasty section and that was driver error for not taking a better look at what I was going over at night. Either way it accomplished the job wonderfully and was made with all stuff I just had sitting here already.
Kmrtnsn
What is the departure angle now in back? 8-9 degrees for 40-45"? I'd be concerned about it dragging over even modest ledges. Out West, even on something as tame as the Mojave Road you'd either tear it completely off, or bend it up into the tire. You might give some consideration to doing a gooseneck instead of that straight bar, just to get the rack up and away from the ground.
jscherb
So I have been looking for a good way to carry extra fuel on the outside of my jeep without a roof rack or wanting to mount 50 pound cans on my spare tire...
Why 4 cans/20 gallons of fuel, seems like a lot - do you need that much extra fuel for the trips your taking?
precision powder
Backwoods Explorer
As mentioned before I don't care about departure angle. I dont crawl over rocks, I dont drop off ledges, etc. Everything I do is old dirt roads and logging roads. Occasionally there are washouts, popped culverts, and some muddy sections but again nothing that will cause issues for that. I don't enjoy rock crawling, mudding, or anything else that rough, it's just not for me. At the same time there is no place in the state you can really do that. We do not have trail systems for that, we have dirt roads covering more than half the state. The departure angle is equivalent to a full size truck. In fact i had less issues than 2 full size trucks I saw this weekend
Yes, there are times I go and spend a week or two riding around and I will never see a gas station The entire north western part of the state basically doesnt even have town names it is all unpopulated working woods for the logging industry. To put things in perspective this past weekend where I went the loggers go and live up there off the grid for months at a time hauling wood. In addition I always like to have at least a can more than I need in case something happens. I can only get about 300 miles out of a tank in the Jeep driving on tar at 55-65 turn that down to driving in 1st or 2nd gear or riding around at 30 and you dont really get the same distance.
That same 20 gallons of fuel can become 10 gallons of fuel and 10 gallons of water too, or any combination really. Or 10 gallons of fuel with storage in the middle. Depends on the trip and if I take my other Jeep. My cj only gets 6mpg with the v8 swap
HRPINDC
Nice work! Quadratech sells a receiver hitch that uses three square tubes instead of just the one in the middle. That might be more secure than the turnbuckles. Just a thought. I wish I had your welding skills.
precision powder
Backwoods Explorer
Thank you, the turn buckles just take out the slack. The hitch pin does all the real holding power I hit some nasty bumps and the guy behind me said it didn't even move. Any one can weld really, I got this from a friend who was moving and just taught myself in my spare time. Welding with gas makes a massive difference if you are trying to learn.
Simons
1000 times better than what you'd buy from Harbor Freight! (or Princess Auto up here) A well done purpose built project!
jscusmcvet
Nice welding and thanks for the explanation re: departure angle. Beauty of the jeep IMO is that you can build as YOU need. Nice.
precision powder
Backwoods Explorer
I didn't know HF carried something like this. I just sort of went with it and made the design up on the fly adding things as needed/or that I saw fit. I may have over engineered it a bit but when something works you can't complain!
Thank you. Exactly my thought, I knew some people would complain about departure angle but I have no plans for trips like that. At the end of the day though it works for what I need and it exactly solves the issue I had at hand....which was how to securely carry 20 gallons of fuel without putting gas inside without any modifications. I am not ready to go spend $1600-2000 on a roof rack to just carry some gas. This was all scrap steel just sitting in my shop from past jobs. For the price of free it turned out pretty well.
This is a lot of what I travel on, with the occasional washed out road, popped culvert, etc. Roads are rough, not something I would drive a car on but nothing that this would prevent me from traveling. The distance from the tire to the back of the rack is no more than a normal full size truck from tire to bumper.
reskar
Nice, I'm gearing up for the trip at the end of the month myself. Looks like that rack will be a perfect addition!
precision powder
Backwoods Explorer
If I have enough time I want to make a table that drops over the top of it. Then I can either use it right on the rack or stand alone to cook on. Then I wont have to bring my roll up aluminum table
reskar
that would be nice, prep space is always at a premium. I think I'm just going cold food for the weekend and saving myself the trouble.
jscusmcvet
Envious of the open space and being able to travel for that amount of time without running into gas stations :). Wife and I were just talking about a someday trip hopping up the east coast, hitting historical sites and also places neither of us have ever been... like Maine.
precision powder
Backwoods Explorer
It is pretty great but sometimes a pain. If you get on google earth and look for Moosehead lake, basically everything north and to the west of the interstate is uninhabited, maybe a camp or a lodge here and there. The only exceptions are Medway/Millinocket which is right off the highway and are logging towns, and Greenville/rockwood. Just hundreds of miles of dirt roads. It's all logging areas. The guys live right in the woods. Sometimes you come across little lodges that have some 91 oct but generally just during the winter for snowmobiles and its $5-6 a gallon.
MOguy
As mentioned before I don't care about departure angle. I dont crawl over rocks...
Great work. If you ever decide to drive tougher terrain you can do what I did. Just add another receiver for your basket. Mounting it up here will allow you to open your tailgate without having to take things off.
