Teardrop Project - Eastern NC $1000
Pitch
Teardrop trailer project for sale:
5x9 powder coated trailer made with 2" x 2" square tubing registered and titled in NC
3500# Axle with 5x5 bolt pattern to match Jeep JK
Precut 5'x9' marine grade plywood for walls.
BAL 30" Light Trailer Stabilizing Jack on each corner of trailer
Teardrop trailer door still in box
2 teardrop trailer windows still in box
Pitch
Fully welded frame. I built it in the welding shop on base and was supervised by two certified welders. It is all 2x2 square tubing and was powdercoated.
dakota123
So you have the title for the trailer I'm assuming? How hard would it be to transfer it to a PA title?
Pitch
I have the title. I would assume it is like any other title, take it to DMV and pay the fee but I have never titled anything in PA.
jpstewart19
Interested in your teardrop project. I am in chapel hill. Do you have plans you were building against that I can use to finish the project or is it more of a wing it? Also, what is the brake and suspension system?
Pitch
I was using a modified generic Benroy plan off the internet. The plan was modified to make it one foot taller, wider and longer. The trailer does not have brakes but electric brakes can be easily installed. It has a leaf sprung suspension with 3500# springs. I also have a set of 2500# springs in case the 3500# springs were to stiff.
Houie
