OK4WD Daily Driver / Overland Rubicon
rino
Approved Vendor - OK4WD
Definitely like the tie down rails that tie into your top mounts. :beer:
Thanks, they are made by MAC tie downs. They do however require drilling to clear the hardtop "locating studs". I can post some more shots if you are interested!
Comanche Scott
Do you sell them through your store? If so, I'll just contact you there when I'm ready.
If I'm seeing them correctly, they could be used with or without the top being on. That would be very handy.
I have side racks, so would need to do just a *bit* of fab work to fit them correctly any way.
Definitely like the concept, and the execution on your rig. :beer:
rino
Thanks man! :beer: Yes we have them in stock and I can even pre drill them for you if you would like.
rino
Some shots of the Rubicon at the Jeep Invasion in Wildwood NJ. :beer:
fireball
Hi Rin, nice to see you again, thanks for showing me around the shop and the James Baroud tents. Very nice units, we will be giving a serious think about the smaller unit vs. the "King Size Palace" GrandRaid XXL.
rino
So glad you were able to come down! Thanks again and if you decide so let me know and I would be happy to help you! :) Awesome rig btw! You had Chuck jealous!
rino
Had a very productive day off this week and made some progress on the Rubicon! :beer:
First on the list was to ditch the stock battery after having killed it a dozen times in the past two months. I was debating springing for the Genesis Dual Battery Kit, but with less than a year to my wedding I have to keep the budget down! haha With that I chose to try an ODYSSEY PC1220.
OLD vs NEW
Installed
rino
I also have thought of adding a watt meter to my fridge for quite some time, to monitor the battery voltage and power consumption of the fridge.
All mounted up:
rino
I also mounted up a reverse light on the AEV carrier. I have been searching for quite a bit for a light that looked like the classic IPF reverse light but with LED output and to me this is the light. Almost 4,000 lumens and it matches the ARB Intensity brackets nicely! :) This model is the RIGID D2 XL in the diffused pattern, the same pattern I chose for the SR-M awning lights.
