International 4700 Ambo build
Baloo
"The Bear Necessities"
Found a little coolant leak from the radiator drain petcock. Replaced an O-ring, held 13psi for an hour. Filled with coolant, no more leak!
Baloo
Two weeks on the road, first issue came up, all fixed up now.
Philadelphia
Ive been coming here off and on for a while. Great build.I can appreciate the amount of work you have put in so far. Great build brother
Baloo
Looks good! I'm jealous of your disk brakes :sombrero:
Thanks, I have to be careful when braking, the brakes on this thing can put you through the windshield if you press too hard.
Put some miles on the ambo, installed a new to me alcohol stove.
Baloo
Transmission swap time! I got the ambo a new toy, that being an Eaton FS5306A. Now if I could just find the time to get it installed!
I did get to tow my camper with it for the first time, and even with the automatic tranny it pulls like the camper wasn't even there!
DzlToy
The new transmission is a 6 speed? What ratios? OD or 1:1 final?
First match in google:
FS-5306A, rated at 520 pounds of torque at max GVW
Reverse Gear: 8.63
First: 9.01
Second: 5.27
Third: 3.22
Fourth: 2.04
Fifth: 1.36
Sixth: 1.00
Length: 25.6 inches
Weight: 342 pounds
PTO: 52% of engine speed
gp01
