Rollercam straps
bluejeep
just a guy
I read the tiedown strap comparison test that the overland journal did a while back. Liked what I saw about the ease of use and security of the Rollercam product so I bought a few. Here's my thoughts on the Rollercam strap products.
The product is amazing. But.....they are more useful with the slight modification I made.
I cut the strap approx. 18" from the buckle end. Then I looped the cut end back onto itself and sewed it to form a loop approx 3" diameter. Did the same to the cut end of the other portion as well.
So you now have 2 sections. One shorter length with the rollercam on one end and a loop on the other. The other section has a loop on one end and a plain strap end on the other.
Now my strap works 4 ways.
First- each non-looped end (plain strap end on one, rollercam buckle on one) can thread thru a tiedown loop on my jeep and then thru its own looped end. Then each non-looped end (plain strap end on one, rollercam buckle on one) connects to each other as usual with the plain* strap end running thru the rollercam, pull to tighten, drive with confidence from south dakota to Texas! Did it!
Second method - each non-looped end (plain strap end on one, rollercam buckle on one) can thread thru the loop on the other portion from the original cut strap. Now you once again have a long continuous strap, like the original.
Thirdly - each loop end can slide over a hook tiedown, connect the other ends as usual
Fourth method - a load rated caribiner can connect each loop end to a loop style tiedown, connect the other ends as usual.
I recommend this product.
Honu
lost on the mainland
PICS :)
pretty sure I get the concept :) just would help to see
I have a lot of these type straps and like them very much !
spressomon
X3
Been a happy Rollercam strap user for a few years...great product...since getting them, regular/old style cam buckle straps and el cheapo ratchet straps are no bueno.
Wish he would intro a wider, say 2" wide, version.
Honu
for sure a great idea that has my mind going :) now to get out the sewing machine :) hahahahahah
bluejeep
just a guy
PICS :)
I'll see if I can get some pics, I just listed my house for sale and am still 'polishing' all those little aesthetic things you say you will get to 'some day'. So now that I want top dollar, it's 'some day' today! Might be several days.
I sent an email to Rollercam with the same words as my original post, and the reply indicated "We will be releasing a variety of new products and configurations in the upcoming months, of which, loops will be prevalent." !!!:wings:
bluejeep
just a guy
let's try some pics
this shows the strap after if was cut into 2 sections, and loops sewn into one end of each section
detail of sewing (no load rating tested)
Next is the 2 sections inter-weaved to make one long strap again, shown loosely configured and then also snugged up. Similar to how 2 recovery straps can be connected.
then a pic of being connected directly to a tie down point
Now shown with a load rated connector between the strap's loop and the tie down point
Sorry, I don't have a tiedown point that is 'open', like a hook
This strap started it's life as a 4' length, which I used in the pics to illustrate things, longer straps would be done the same way
Honu
very cool :) and what I thought but fun to see
I know the track tie downs what are the other ones the nice clean simple bend ones :)
doug720
The tie down anchors in post #12 are motorcycle triple tree anchors. Most MC dealers sell them for $8-12 a pair, not $9 each.
