Egan70
Yeti 400 on sale at Amazon today only $310: http://www.amazon.com/Goal-Zero-230..._1?s=automotive&ie=UTF8&qid=1435063036&sr=1-1
Deal or no deal?
			Deal or no deal?
Deal or no deal?
Deal or no deal?
I found the GZ connector you reference above, but didn't find the crimp on Renogy ones.
The anderson ports on the Yeti 400 are a direct connection to the battery through a fuse, there is one fuse for each port. I think it was a 30A, can't recall from the last time I opened it up for some exploratory surgery(I'm in the process of modding my yeti 400 with extra ports and such). The anderson ports do not go through the controlling circuitry in the Yeti.
This means two things: 1. you won't get any of the features of the electronics such as the over discharge protection and watts in/out when using this port. 2. you are getting direct access to the battery in parallel to the rest of the system.
However, you will be able to use the built in battery level indicator.
Just treat the anderson ports as if you are connecting directly to the battery and it will be fine. As long as you trust the external charge controller you will be okay. The only thing to watch out for is not to use the stock 8mm input while you are charging with the external charge controller, that is don't charge from the internal controller and the external controller at the same time.
You are right that it would make no sense to make an adapter that went from the renogy charge controller to the 8mm port. Solar panel->charge controller->charge controller->battery. It will be redundant and I doubt the external charge controller will be able to read the battery voltage through the internal charge controller. Not to mention you will lose energy through extra connections and voltage regulation of two charge controllers.
Hey All,
I just picked up a couple of Yeti 400's from the Amazon deal. I just opened them up and I noticed a few things:
1. The charging light is different on each one. One has a blue light, the other has a green light. Is this an indication of different panel (one is newer, one is older?)? I talked to Goal Zero and they said it's just different manufacturers, but I noticed on this thread someone said their repaired Yeti has blue lights instead.
2. The Power supplies hum like crazy, and are pretty hot. Proprietary connection, so was wondering if anyone had any luck in mitigating this.
Looking forward to using this for some tailgating this summer, and for backup power in the winter in case of power outages.
I posted on the front panel change. ALL the newest GZ devices have Blue lights for charging. Your one with a Green light IS older but may not be different in any other way. My Yeti was over 2 years old.
The A/C chargers SUCK. Buzzy and hot. Myself and others have adapted cables to allow connecting to the 8mm port. Check pages 7 and 8 of this thread. I have not tried to replace the A/C charger per say because I don't use it much. Instead I turned to solar and I maximized my ability to charge from a vehicle. See this set up at http://www.expeditionportal.com/forum/threads/142417-Ultimate-Goal-Zero-In-Car-charging
Matt
Matt - thanks for the info.
I think I might get one of the chargers replaced because it's free (I think), and one of them is really loud. The end goal is to charge using solar only - right now I am looking for a good deal on panels. I am thinking of getting the renogy solar suitcase w/o the charge controller and adding mc4 connectors (when I bring it to tailgate). Do you or anyone have experience with that particular panel? It seems to be more on the expensive end but I don't think their regular panels are very portable (I have a sedan). They may work nicely for home though.
What did you do to wire the yeti in your vehicle? I'm looking at the thread you pointed me to and I think that would be great, but I'm not very versed (yet) in the electrical system of my car.
Edit: I read a little further back and see what you did... how much did that installation run you?
Joe
Hey Joe I just built my own power system. I think knowing your power needs should be sorted out before you pick your panels especially if stowage space is limited while on the move. I have no idea what your power needs are but in my case I have two very compact 10watt renogy panels which I charge an 18ah battery that sits in a 50caliber ammo box with a solar controller, fuse block etc. Our power use is for some LED lighting max burn would be just over 3amps per hour if every light we had was turned on which will not be a very common situation. Then we have a 12volt charging hub which we use to charge various small stuff like camera, cellphone, Ipad and maybe on rare occasions a laptop etc. I figure our non solar generation hours worst case we might burn 8-10 amps of battery capacity over night and even on the foggy coastal CA I found that we were charged up and in great shape by the end of the day when only 2-3 hours were fog free. Now keep in mind my power use is very very minimal.
Knowing what your power needs could have a dramatic impact on the panel choice you need, possible you may find that going smaller will be fine. Also I went with two 10watt panels given I wanted the smallest packed size possible and knew that I could add another 10watt if needed etc. I think in your case it sounds like smaller panels and having one or maybe even three might fit your packing space situation a little better also. Which case I would even consider just buying a case and mounting your panel of your choice in the case if you wanted to go that route. Right now I keep my small panels in their shipping boxes but will eventually either get a laptop style canvas bag with padding to store the panels or possibly make a simple wood compact box to stow them and protect them while on the road.
Thank you for the information - I plan to at some point soon test what I am looking to plug into the Yetis and see what sort of draw I am getting. I'm looking forward to learning more about this. I know where to go to get good information and answers to my questions though!
Deal or no deal?
And... it's back up to $459.99
