My Jeep FC170 (Forward Control) "Patina Rod" project
1x1_Speed_Craig
Not too surprisred about your daughters shooting skills. I know a few women that can out shoot their husbands on the range and a friends mother was the PA champion for clays.
Thanks. Yes, I was pretty impressed with her shooting, for sure.
We moved the cab up to the front garage earlier this week in preparation for the cab install on the Super Duty frame.
The FC cab is now leveled on the dolly fore & aft. I started taking several reference measurements on the FC cab and '08 Super Duty frame so I can start mocking up a temporary front crossmember.
As of earlier today, all glass is removed, original fender flares are removed, and the cab is now level on the casters/dolly.
Rotors are now blasted & painted with caliper paint (they'll be turned at some point before final install). I also bought Grade-8 bolts, and (loosely) mounted the Warn hidden winch brackets.
The front dually adapters are now blasted & powdercoated satin black...pretty!
unkamonkey
I always thought about dropping a 6BT in my Mitso Fuso FG. at least I could avoid holding up traffic on a pass. I end up running about the same speed as the semis so I suppose it could be worse.
1x1_Speed_Craig
Man this thing is so cool.
Love this build... frame is looking new!
Thanks guys. Greg, the frame is actually mostly stock paint at this point. I'll be coating the entire thing with Satin Black once the custom cab mounts are all done (prep will be easy).
First, after careful consideration, I decided to sell the aluminum flatbed I bought last winter. Instead, I'm now looking for an 11-foot service body, which will work much better for the equipment we want to travel with. I'll custom-build panels between the service body and back of the cab, and around the mid-engine set-up. The biggest challenge will be figuring out how to paint the service body to blend with the cab. If anyone knows of a nice, used 11-foot service body, I'd definitely like to hear about it.
My leather interior bits (mix of Jeep Commander and custom pieces) continue to come together.
My custom leather sun visor covers are in-the-works (early stages...they'll match the Commander seats, and new leather arm rests). The font for the "Jeep" logo cutout matches that of the stamping on the front of the FC cab. My co-worker, Clode, does GREAT work.
The visors are being done by my same friend who did the custom arm rest covers.
1x1_Speed_Craig
This is going to be awesome, can't wait to see the drive train in and cab on the chassis.
Thanks! Me either.
Another affordable (and increasingly rare) 47RH auto transmission found its way to me last week...this one a 2WD version. This one only has 114K miles. I'm hoping it's in good-working condition, as it has low miles, and can be converted to 4WD with parts I already have. I'm now up to two (2) 47RH 4WD transmissions, and one (1) 47RH 2WD version.
At some point, I'll probably sell off one of the 4WD versions, if anyone's interested before I throw it up on Craigslist and some Cummins forums.
I also did some more prep/paint work on the passenger frame rail today (inside & out). Once the driver side is done, I can get the radius arms bolted back on, and get the front axle reconnected to the frame. It's not major progress, but it's progress nevertheless.
1x1_Speed_Craig
My wife, Amy, and I just got back from a wonderfully-relaxing vacation in Michigan's Upper Peninsula—hiking, checking out several waterfalls, and just all-around relaxation. Little did I know that our vacation would have some cool FC-related bonuses.
First, I got a text from Arizona-based FC guru Jesse Ybarra that the special order of FC windshields he facilitated for several FC owners is now in. It sounds crazy, but Pilkington is the only known manufacturer of FC150 & FC170 windshields. In fact, decades ago, Pilkington bought out the original FC windshield manufacturer, so these are the real deal, just like the originals. Given the unicorn rarity of these windshields, and the chances that a stone may, at some point, cause the demise of said rare windshield, I ordered two (2) so I'd have one on the shelf.
On our way north, we stopped to look at a very affordable truck "Service Body" that I had found on Craigslist just a few days before I left. $450 snagged me this heavy mutha'; I just need to make a return trip to pick it up. It'll hold all of our camping/expedition gear, and with some modifications/enhancements, give us sleeping quarters.
It's a "narrow body" dually bed—only 90" wide. The outside track of my chassis cab Dana 80 is 92.2", so with some small custom flares, it'll be a great width for my truck without being ridiculously wide.
The passenger rear corner, at one time, supported a boom of some sort. It's HEAVY-duty construction. The plate on top is ~3/8" thick. I may mount a small, detachable manual crane back there (for lifting heavy parts) because—well—the last 15 years establish that it happens on a semi-regular basis.
A couple of the doors are dented, but this doesn't affect the usability. I'll be able to either straighten them, or rebuild replacements.
Several of the storage compartments have shallow drawers on slides. I'm not sure yet how we'll use these drawers, but we'll certainly figure it out! It also has shallow (4-5" deep) "top-sider" storage (under the black diamond plate lids) on both sides.
One of the front doors accesses a "pass-through" tunnel that spans the width of the bed (you can see this tunnel on the front of the bed). This originally held one of the tanks for a torch set. I have a couple ideas as to how we'll use the space. More to come.
We're not sure how much of the original overhead rack we'll keep as-is, but we'll certainly re-use any of the steel we remove. I do like that it has built-in ratchet straps, too!
Fast-forward a couple days, and while we're driving in Munising, Michigan, I saw none other than Roam Automotive's infamous "Forward Frank" pulling into a gas station. We whipped in, and I proceeded to meet & talk with Tom, one of the Roam co-owners and an all-around great guy.
If you haven't heard/read about the Forward Frank build, you must do so HERE on the Roam Automotive website.
On the return trip home, we stopped by the Roam Automotive headquarters and met TJ, the other (equally cool) co-owner, and got a shop tour. Oh, and we brought some Roam bits back home with us, too.
But THIS is what our week was really about...
Miner's Falls, Munising, Michigan
Evening dinner date & walk in Houghton, Michigan
Quincy Mine tour (Hancock, Michigan)
Lake Superior at Presque Isle
Boost Creep
are you going to keep the strobe lights too? lol. service bed looks like its in overall pretty decent condition. good score. Munising and that whole area of michigan is a great area to explore.
1x1_Speed_Craig
LOL. No. Yes, Michigan is a beautiful state, and the U.P. scenery is quite amazing.
Three (3) new FC windshields arrived from Pilkington on Friday...one for my Patina Rod, one to keep on the shelf as a spare (only one company in the U.S. produces these), and one for my friend Darrin's FC150.
We got the service/utility body for the FC home safely (from Freesoil, near Manistee) this weekend, as well. Now to figure out how to unload this heavy beast. I'll probably have to give my friends at G2, Inc. (crane rentals) a call this week. As always, a HUGE thanks to my patient & loving wife, partner & co-pilot, Amy.
And here's a scale rendering of the service body with the FC cab on the '08 Super Duty frame (165" WB). The drawing shows extra cabinets that would have to be built around the (mid-)engine.
With the help of my wife, a buddy's chainfall, and perhaps some inspiration from David Copperfield, the FC cab is now hovering above the '08 Super Duty frame.
I'll have to do some cutting/carving on the rear sheet metal & corners—including fabricating new rear body mounts on the cab—to clear the frame rails before lowering it to the proper height.
Zeep
Things are progressing nicely. I've done a lot of hunting & snowmobiling in the Freesoil area.
I think it would be cool to add some led lighting to the interior of the service body.
