What did you do to your Expo Jeep today?
Maxcustody
Got a Rhino-Rack Backbone with Pioneer platform installed and picked up the new tent.....
Sent from my Roof Top Tent
MTSN
Installed a set of JW Speaker Evo 2 Headlights.
I'd suggest painting the trim rings flat black and adding a horizontal adjustment screw if you haven't already. I did those two things and my impression of the headlights went up about double.
Skennedy
Going to do that thought I had paint when I started the install.......I was wrong !!!!!
Love the improvement.
AdventureHare
Outfitting for Adv
Where does the seatbelt buckle anchor? If it anchors to the body, the forward momentum is handled by the seatbelt anchors. If it anchors to the seat or seat frame, the seat and seat frame bolts are responsible for restraint. In this second case, you should replace the rusted bolts and use grade 8 on all that are responsible for keep you and the seat from going thru the windshield.
PCO6
The seat belt buckles are anchored to the Hyundai seats - same as the original Jeep seats were. The bolts in the picture are all now grade 8 (the pic is of the mock up before the brackets were removed and painted). The bracket bolts to the floor are the originals. The Jeep is 12 years old and very rust free. I'll replace them at some point but I'm not worried about them now.
mtbxj87
Built a cargo/ sleeping platform in the xj. Mounted solid, no hole drilled through floor and can be removed in about 5 minutes. needs carpeting
V45W_Proto2.5
