"Arctica" 2015 Crewmax Platinum Tundra Build
wikid
Truck as it comes
2015 Crewmax Platinum (white)
I did get the AMP steps and ordered the remote start.
I cancelled the remote start, because it has problems
I ordered the TRD Pro grill .
I picked her up from Findlay
The Plan
Build a Expo/Chase type truck. It will have to have all the right components to qualify this. It needs to be able to pull my camper, or my car trailer with my dedicated trail rig. To keep the Expo thought in mind, it will also have an RTT for when I pull the trail rig.
There is also more plans for this build. I just can't speak about it yet
I had to special order this, so I could get a non Flex Fuel . More on this
Here would be the real reason for not getting a Flex Fuel model. The Supercharger was waiting at the dealer, before the truck arrived. Installed with 8 miles on the clock
Also waiting at the dealer was this
and this..
Transfer Flow replacement fuel tank. http://www.transferflow.com/shop/product/0800114225?p=1&c=10&s=p-
Using the code "TUNDRA100", will get you 100 bucks off your purchase
The tech at the dealer, said it would be no problem to do the tank install, while installing the s/c ,since the tank needed to be dropped anyway. It only added 1 hour ,to the install. He said they use every available inch, in that tank location
Here is what 3/4 of a tank of gas looks like
Can you say range?
After I brought it home, this was waiting for install.
Ba Muffler dual TRD Replacement , with TRD Tailpipes. I painted them with several coats of semi gloss grill paint and heat treated them before the install . This is a mellow system, since I really wanted to keep the drone and cabin noise down, but it is louder than the TRD
More stuff to add
Engel Refrigerator, will be put in the bed. It will stay in the truck along with having a dual battery, solar panel, Ham Radio, cb, and more
This build will not be one of these way over the top, spacer lift builds.
The plan is to run 35" tires with a full suspension under it. I am building this to drive, camp explore and even have a little romping fun .
I decided I love the look of the Rock Warrior wheels, that falls in line with the function of this truck 17" , light, strong and will fit, with close to the back spacing I want to run. More on this later
ARE Z Series shell
This will fall in line with my future mods. I will be doing a hard shelled , Roof Top Tent. I also have a 17 ft Viking camper, i will pull to events and destinations, but the Roof Top Tent will be in place, for when I pull a car trailer, with a first Gen 4 Runner, for harder trails and rock crawling . Then I still have camping off the ground, which is big for the wife .
Suspension
I am working with Nicole at Total Chaos http://chaosfab.com/
to design this as a Mid Travel set up. Long travel requires too much maintenance, fender replacements and also makes the truck much wider. It's already wide enough
Total Chaos Upper control arms
Total Chaos shock hoops
http://www.ridefox.com/
Fox 2.5 DSC remote Resi's in front
Fox 2.5 triple bypass shocks in front
Fox 2.5 DSC Remote Resi's in the rear
Deavers with Total Chaos shackles
Here is the shiny parts, all in one place awaiting install
Everything was on order in mid May . It's all been built and is sitting at Total Chaos for the install . The will be a professional video shot with suspension performance stock, then install, then performance after the install
We will pick a desert location for this. The Suspension install should happen in Mid September, due to some R&D going on .
If everything goes as planned it will be in Total Chaos booth at the Off-Road Expo in Pomona October 3-5th 2015
Wheels and Tires
I decided to go with the Toyota Rock Warrior Wheels in gray.
a few reasons. They are forged and strong, they also are able to fit with the correct backspace to be able to mount 35" tires Even with the stock suspension and no lift
The tires are General Grabber Red Letters 35/12.50/17
They are really strong and probably the sexiest looking tire out.
http://generaltire.com/tires/light-truck-crossover-suv/grabber
To fill the area correctly I decided to get the Bushwacker Extended Flares. http://www.bushwacker.com/ I didn't really care for the pocket flares with the bolts. This is basically wheel tire fitment and test fit for the Bushwackers. They will be removed to get them body color matched
A few small adjustments to the skid plate and front inner fender plastic and there is no rub :)
wikid
Next up Bumpers
http://www.exp-one.com/products/tundra-2014/
I was looking for a clean look for the front. I didn't want bull bars to obstruct the grill since there is a plan for that. Expedition One has always made quality bumpers. The fit and finish are top notch. The instructions are clear and all the parts were there. The bumper is packaged in a full box with expended foam around everything, so it lessens the possibility of damage in shipment. The front is first, but the rear will be on its way
Communication
Kenwood 710-G Dual band with Aprs
Diamond HAB 770 With a 5" mag mount (temporarily)
The base is mounted under the drivers seat
Next up Electrical plan
The fun part begins ...
Wiring the truck for lights and stuff
here is the plan so far
First shipment of lights on their way, I should have them tomorrow,07/28
All Baja Designs Baja Designs | Off Road LED Light Bars And LED Lights
(6) Pro S2's 2150 lumens each, that will be mounted on each side of the roof rack (flood pattern)
(2) Squadron Pro's in (wide driving), for the front bumper 4.75 pockets
(2) Squadron sport lights , (wide cornering) for the new Expedition One rear bumper pockets, (on order)
(6) These will be rock lights. I may add a few more under, plus add something under the hood . Yet to be determined
After that the next round of lights will be shipped
Hood Scoop: Qty. (3) Amber 10" Stealth light bars. Two as Amber Wide Driving and one Amber Spot
Front Bumper: Qty. (3) XL auxiliary lights. Two Combo XL80's and one Spot XL Racer Edition, in the middle.
Rear Rack will be (1) S8 20" Amber Wide Driving
We are looking into a grill option, but that is yet to be determined
The next phase will be (6) XL racer editions for the roof, behind the sun roof, preferably on some sort of actuator . I believe these are listed at 9500 lumens each. With the correct combination of patterns, this will be almost total lighting coverage .
I did a chicken scratch doodle wiring diagram,(don't laugh), just to get the idea of where my wire runs were going and how many amps would be required, so I could size the wire correctly. With all the lights blazing at once, it would consume about 85 amps :) That doesn't count frig, compressor, radios etc. Good thing I am running an Odyssey Dual battery
This will complete the lighting design. It was important to have the total configuration planned out, so all the wiring infrastructure could be ran at once. This will save sloppy add-ons, in the future. Even if I change lighting configurations, the wiring could essentially stay the same. Eventually, I will have a total lumen count, but whats more important is the lighting coverage. Working with Baja Designs and their expertise, will get to the goals I want to achieve .
How do I manage all of this?
I took some advice from someone that read one of my posts and contacted Switch-Pros http://switch-pros.com/
After I read what this system will do, in a nice neat package, I decided this is what my Tundra Deserves
The only problem is , that 8 circuits will not be enough to control my massive system. I could actually almost fill up 2 of them. So I will be getting 2 systems. The details include being able to control everything from my I-phone, but having redundancy to able to switch it all manually . I should be able to control both systems at once, too.
I will do strobe and dimming on all circuits and will be able to switch on my compressor, frig and any other things I request it to. For the compressor, it will be a switch function, to a small relay that will trigger a 100 amp relay . I am currently working on a over the fender well platform for the dual battery, compressor , tank and Switch pro modules. It will be positioned, not to interfere with the Bedslide, which is 48.25" wide .
Oh yeah It's getting a Bedslide too . It will be the location I will mount the spare tire.(all the way forward) along with the Engel Refrigerator (all the way Back on the passenger side) If you notice I am mounting everything passenger side, to help balance out the weight, from adding the Transfer Flow Fuel tank
Dual battery is definitely in order.
National Luna Dual Battery Controller http://nationalluna.com/intelsol.htm
Odyssey PC1500 Battery X (2) http://www.odysseybatteries.com/batteries/pc1500rt.htm
Next order of business is rack is on its way, from Equipt .
http://www.equipt1.com/
They have a specific rack that can be mounted to the camper shell, but only be a few inches tall. Then I do all the roof rack wiring and light installation
Onboard Air
Extremeaire Magnum http://www.extremeoutback.com/product/14/ExtremeAire+Magnum+12+Volt+Compressor++Part#+007-222.html
This is a bad boy air system. Yeah I know you can get a Powertank or any other Co2 set up, but I didn't want the string attached to have to fill it and store it. My system will be similar to how I set it up on my FJ Cruiser. Under the truck on a cross member I fabricate (the tire will be moved do to the size anyway)
Here is the write up I did on my FJ Cruiser for the install
http://www.fjcruiserforums.com/forums/4x4-off-road-tech/235201-extremeaire-compressor-install.html
Here is a picture of the somewhat finished project on the FJ
Next order of business is part of the on board air system http://rocksmasher.com/2wayair
It will be a blessing to fill or deflate the tires from one spot. It really has many advantages . I will be taking a road trip to work out the details of the system and will also be an authorized dealer . This will be vehicle specific too, so there won't be any guess work and an easy installation
Lots too do, so little time to do it :)
The first set of lights have been installed
Baja Designs Squadron Pro Series
4350 lumens each 3.6 amps 5000 K color temp
I used the driving light circuit, clipped the stock plug and put a set of Delphi connectors to mate with the lights. The install was a little tedious, just trying to space the lights out correctly so they fit the holes cenetered . They are pretty close
bkg
Going to be watching this one.
Oh... And let me know of you want to sell your white bumpers. :)
wikid
Your FJ build was incredible and this one looks like it will be the same. Are you keeping the FJ or is it up for sale?
Thank you
The FJ had to go , so I could free funds to build this one. I had hard decisions to make, as far as use and function, to fit into my plans. I dedicated trail rig, or one that I can do more with, is part of the plan, then I have the tow vehicle to get me there in style.
RINZLER
Outdoor Enthusiast
Subadubdub!! Looking forward to the next epic build by the almighty Don! :wave: Hopefully we can get another big AZ TW meet together soon so I can see this beast in person man
wikid
Thanks Stefen I appreciate the nice comment. Good to see you here.
Yes, we do need to have another get together . My truck will be at some type of stage, but probably not finished :)
Henrybrowne
