DIY alternatives to BedRug soft carpet mat in bed??
Desert Dan
The bed rug/bed mats look nice and fit well. you can also get the kit that covers the side walls and wheel wells.
Plywood and some cheap carpet remnants and carpet padding. I have done that many times I have done that for different rigs.
blackwood
plywood isnt really that heavy.
I did a web search on the weight and found it to be about 30-40# for a usable sheet. Seems like most of the truck bed builds out there have a sheet of plywood down so I'll probably go for it. I have a long bed so I'll be using most of the sheet. I will probably go with a 1/2".
How much does a sheet of plywood weigh?
The weight varies from 22 - 84.5 pounds depending on the thickness.
For a 4' x 8' sheet (32 sq ft)
1/4" - 22 lbs
3/8" - 28.5 lbs
1/2" - 40.6 lbs
5/8" - 48 lbs
3/4" - 60.8 lbs
1 1/8" - 84.5
Henrybrowne
