Since the water tank took the place of the spare tire, I had to find a new spot for it.
There is no quick or stock way to mount a tire on an Astro van.  I didn't like the whole idea of a swing away tire carrier that had to be unlatched each time the doors were opened.  The only way to make the door and the tire carrier swing together is to have them share the same rotation axis which happens to be the door hinge pins.
Removing the pins was a project in itself and probably the most difficult part of the project.
First I tried tapping them out with a punch and hammer.  Nothing.
Then I tried pressing them out with a home made press I built out of a large C-clamp....Bent the C-clamp.
So I finally decided to buy the right tool for the job.  A small press similar to a chain link tool.  I sucked it up and paid the price.  A few days later, the tool came.  I made short work of....the tool.  It broke too!!
Finally I got out the trusty hack saw.  There was just enough clearance between the hinge knuckles to slip the blade in.  I cut the hinge pins, pulled the door out and tapped the remaining pin parts out of the hinge.
On to the tire carrier...Finally.
I used some rectangular tubing and a couple snug fitting 3/8" bolts to get started.  The tape on the door was an attempt to save the paint.
The other end is bolted on the inside of the door.  Nothing goes through the rear door skin.
This was just tacked in place.  It got majorly trimmed later.
Here it is with the doors closed.
It's really close but there isn't any interference.
This is the rough upper portion of the tire carrier in place.
The lower portion connected the lower hinge and the bolted plate.
Since the lower section crossed the compound curve of the door, it couldn't be a straight section.
I cut a V-shaped notch in the tube, bent, and rewelded it.
Next I started fabbing up the tire mount.
A couple pieced of tubing cut at the right angles worked out pretty well.  The only thing to take into account was the distance from the wheels mounting surface to the inner edge of the tire.
I match marked the bolt pattern on the disk and drilled some pilot holes in the mounting plate.
Other parts got trimmed and sharp corners got chamfered.
It's tight but doesn't touch the door anywhere.
I pulled it off for paint and wheel studs.
Painted and back on the VAN.
Made it look easy right?
Wheel is on like it was "designed" for it.
...Rear mounted spare....plus 5 EXPO points.
