Quigley with Airbags in the Frontsprings
keeper
In the frontsprings of our Quigley there are Airbags....in the back..ok...but for what I can use them in the front? I feel no different taking more or less air in it.
If I put them out of there did I need bumpstoppers in the front?
simple
Can you post a picture? I'd like to see the arrangement for curiosity sake. I'm sure there's folks on here though that are already familiar with your setup.
BajaSportsmobile
Baja Ironman
We have removed a few sets of those from Quigleys - another band-aid fix to keep them form bottoming out all the time.
BajaSportsmobile
Baja Ironman
Did Quigley also use that system to so they could fit a smaller diameter coil spring in there?
No, Quigley is restricted to using OEM Ford components from the van. These blue air bags are something someone installed to try to solve the under-sprung situation.
You can see in his pictures that there is only about 1.5 inches of bump travel. The bags won't lift the van only make it harder to bottom it out. Bad deal!
martell06
I think since they were sold on Ford lots A. They had to as required by Ford - easier to service
B. Keeps conversion cost to a minumum
derjack
What's the deal with that? Insurance or Patents?
Nothing to do with patents. IF this would have to do patents Quigley would have to pay a fee AND they would not be allowed to change anything critical, which they did. This is generally the "idea" of patents.
I guess it comes down to costs and cut corners. Its just faster and cheaper "engeneering" to build something around a none fitting thing (solid axle) to make it kind of fit. Using the old parts saves a LOT of engeneering costs and (very important) after sales costs in the long run. Imagine a fleet that wants to have save repair parts for 10 years!
The other way for a 4x4 would cost Quigley way beyond they did with this cut-corner-4x4. There is a lot of "if you do this, you need to do that....".
ert01
I think it also comes down to warranty... If Quigley can do a conversion using mainly Ford parts and sell them on Ford lots, then warranty work is:
1) easier for the Ford tech to do since the parts are stocked in their warehouses
2) familiar parts for the Ford techs to use
3) the parts are not made by Quigley, so if a coil spring sags or breaks due to manufacturer defect, then it's on Ford, not Quigley
IMHO it's a smart way to build. It ensures that even if Quigley goes under, that the van owners can still find parts and service.
Clemtiger84
