Oddity
Wondering if anyone has done this before.
Currently don't have any points to lift with a hi-lift (neither rock sliders, nor steel bumpers), but saw the "Lift Mate" attachment that lifts from the wheel. By the looks of it, there is a pad up top that supports the jack against the tire. In the event of a flat, I would jack up the wheel, place a jack stand under the axle anr remove the hi-lift, fix/replace the flat, then hook up the hi-lift and lower again. My concern is that with a flat, there won't be enough pressure in the tire to support the lateral force of the hi-lift, rendering the hi-lift useless.
I need something that will lift the truck now that it has been leveled out and sitting on 35's. Eventually I will get my armor sorted for lift points, this is in the meantime.
