Hopefully these will give you an idea of how the install is. You cut off the bumper mounts, use the bracket to make a template of where to drill your holes, insert the support tubes that come with the bumper, and then bolt it on. I was able to do it in my car port in about 3hrs start to finish. It will come with some instructions that are pretty detailed.
I ended up having to remove my tow hooks, and fog lights for the install. I mounted a set of 6" led lights angled down and out, and just wired them into the original fog light harnesses. Still working like factory just twice as bright.
