Flatbed and composite panel build on Dodge 2500
Jeep
Supporting Sponsor: Overland Explorer Expedition V
This camper is only 7' wide so it fits a queen bed nice, and there will probably be a little storage available as there is good height in the overhead, I could also go into the main cabinet with an insert which would work good. This unit has a massive amount of storage for it's size, and floor space has a decent flow to it so far. There are also the lower outside storage cabinets on the deck and I have a wall mounted storage locker for the rear outside wall of the camper.
The 3 holes are for Heki skylights, the front one is big enough to legally qualify for an escape hatch. I'm not putting AC or a fan in, we don't have fans or AC in the big truck and it stays nice and cool with windows, skylights, and a breeze, we will see how this one works out, can always add those if needed. There is a thermal dynamic evaluation coming soon!
Healeyjet
Wow, a "thermal dynamic evaluation coming soon!" Of course there is and we would expect no less. :bowdown: Your attention to detail and testing is beyond compare.
Ward
Jeep
Ward
That's what happens when nobody can give you a REAL answer. A lot of assumptions are made regarding thermal values in the panel world, I hate the "it should" comment, everybody knows that!
Jeep
Beakin off
Got the nose on, I like it, it now looks like a skinny camper from the front. Adhesive, and corner caps next, and finish the interior.
Jeep
Windows will be going in pretty quick now, just doing the dinette structure, and upper cabinet bank and away we go!
Jeep
Cleaned my desk today while one of my guys welded up the the reservoir for the hydronic heating system. A good friend of mine builds high end river boats for a living and has perfected the reservoir volume and heat exchanger volume to keep the interiors warm on his boats, small enough to heat up in minutes, large enough to reduce the heater cycling to keep things running clean, he's a perfectionist, I'm not going to argue the experience, but I will borrow the knowledge!
Sixinarow
Awesome, Jeep. I'm envious of your skills!
Little off topic but can you tell me the dimensions of the camper on the 650?
Thanks!
Jeep
Thanks, the 650 camper is 14' on the floor, 17' with the kick out, rear queen bed sits back there, 8' wide 7' tall inside, the overhead is 6' long. Its pretty roomy inside for 4 people.
leelikesbikes
are you friends with the outlaw eagle guys? all of you guys are building some seriously awesome stuff in close proximity to each other.
Jeep
Started assembling the lower cabinet bank, 16" long drawers with full extension slides, 100 lb capacity.
Once everything is in, squared, and adjusted, the lower flange gets bonded to the floor, and the rear flange gets bonded to the wall. Makes the whole cabinet it base extremely strong.
zhukoveli
