What did you do to your Expo Jeep today?
comptiger5000
Looking at the second pic, yeah, those tires will be fine. A little more pinched than is ideal, but not enough to be a problem. The first picture made it look worse.
Bob Freda
Weird mishap! During a Vermont trail ride last weekend I drove over a basketball sized rock with my driver side front tire. It felt like it got caught under a crossmember or skid plate . I dragged it for a few yards, then tried reversing with no luck jarring it loose. When I got out to see what was going on I was shocked to see the rock sitting at the top of my tire and the fender completely destroyed ! It also triggered ABS, Traction Control, and a lot of warning lights but that was due to a loosened wire connection. Live and Learn!
SSF556
SE Expedition Society
HEMI power....
comptiger5000
New rear springs showed up yesterday, so I'll have a good bit to do this weekend: lower the body side of the rear track bar, install new rear springs, tweak the prothane inserts in my rear springs a little and probably pull the intake manifold to try to find an oil leak that's hiding somewhere behind it.
And of course, the springs will continue my trend of buying new springs and attacking them with an angle grinder before I ever use them.
Maxcustody
That looks like a great setup. Who makes it?
It is Eezi Awn Bat 270 awning and the separate wall kit. Paul From Equipt 1 sells them.
Am I seeing things, or does it not close off the back far corner of the jeep in that last photo?
That is correct, you can get the extension piece to totally enclose it, however I chose not to. I can always add it in the future..................
Comanche Scott
Maxcustody
Very nice when's the next anvil outing I need a road trip to hang out with all you guys.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Thanks. I have in for several jobs............California, Arizona and Colorado. Just waiting to hear on selection and transfer. Do a road trip you will have a place to stay!
rubicon91
Oh I will definitely take you up on that. Would love to see any of those 3 states for sure. Good luck and keep us in the loop on where you are heading.
DFWSFO
