Bringing Sexy Back. AKA 93' LWB RRC
getlost4x4
I have moved the range rover in preparation of the diesel install. These car dollies sure make it easy to put it in my garage sideways good thing I have a third garage. Sorry about the glare. I installed some new LED light bulbs into my fluorescent fixtures. Is so nice and bright in the garage now!
getlost4x4
I ordered some larger elements for the injection pump. Stock is 5.5mm and the new ones will be 8mm.
Also got a small intercooler. I haven't figured out where to put it yet, I don't want to cut up the core support much.
And I got the turbo clocked and mocked up. I just need to pull the oil pan and reseal it. Then new front and rear seals.
getlost4x4
This is the intercooler I bought. Its supposed to fit a Mitsubishi Eclipse. Wonder if it'll handle 18 psi.
Ray_G
Is it sitting on its side? Looks like a FMIC, and if it is anything like the one I had on my 2nd Gen DSM you will be fine...I was running 19-21 PSI on her. Ah the days of being a quasi-ricer, I still would take that car back in a heartbeat as it brought a smile everytime it launched and didn't even squeal tires destroying cars off the line.
94Discovery
R u considering beafing up the auto transsmission ???? 8mm element is used on 400plus hp on OM 606 ,check ashcroft for upgrades to the Zf hp 22 to 24 internals
getlost4x4
Yeah, I 'm going to start around 10 psi and work my way up to 18. I'll probably settle on 15psi.
The transmission has 110K miles i think. SO, it may not last long. But its always shifted really smooth and drives great. I'm probably going to get an LT230 for it as well
PNWav
