1991 Mitsubishi Montero $500
RyanSD
SOLD will advise if anyhting falls through
Its a sad day, putting Monte up for sale. Instead of giving it away on CL I'm posting here first in hopes of finding some like minded individuals who see what I see in Monte:
A capable off road explorer
A cool looking square body style with round headlights
A practical utilitarian vehicle
Other great things about Monte are the excellent visibility,overall practicality-there are tie downs and tow hooks everywhere you need them, has a rack strong enough to carry some lumber, large cargo area in the back.
Runs and drives fine and has never overheated or even gotten close that I have seen. However I am pretty sure it needs a head gasket. I could be wrong but upon cold starts white smoke (quite a bit sometimes) that smells slightly sweet blows out of the tailpipe for a couple minutes then goes away. Also Monty uses some coolant (and doesn't have a leak..)I don't see any oil in the water or vice versa. Engine runs a little rough when cold. I still run around town on the weekends with no issues, however those symptoms should be addressed before any remote travel. Passed CA smog in 2013 with a new catalytic converter, I don't know if it will now or not, if the head gasket is blown, I don't know if that effects smog, sold as is. 140,000 miles. 4X4 works great, tranny works great, AT tires are probably 50%, stock, pretty much everything works, except the AC is not cold and the sunroof sticks. Interior is in good shape. New timing belt, starter, alternator, high flow air filter, plugs, wires, coil, cap, rotor, windshield,various sensors here and there, recent battery, recent manual hubs, have new kyb shocks (not installed). Only 1 small area of rust (1"x1") under windshield. I have really enjoyed this vehicle. I'm selling because 1. I'm buying a new truck and 2. I don't really have time to tinker with Monte anymore.
baja1
Where in San Diego are you located? Could you send me a number to call you.
Thanks!
v_man
Nice Monty, I wouldn't assume head gasket if it only blows white in the morning, and when it's cold. It could be condensation or valve stem seals leaking oil slightly...
RyanSD
Thank you.
True. It could be an easier fix. Just haven't had the time to run around town to get it diagnosed.
RyanSD
Interior is in good shape. Its got sand on the floor from a recent beach trip at the moment. Small tear in drivers seat.
mapper
Not to muck up this thread but it appears vehicle has sold. Hope no offense is taken.
My best to the new owner of this little classic styled truck. If he/she has any interest in a full running/driving drivetrain, including locking rear diff, 3.5 sohc engine and all supporting electronics from a gen 2.5 montero please contact me. My 2.5 was hit but the drivetrain works perfectly and is also looking for a good home.
little1er
Still have that locking different?
I ended up buying this Monte from this owner. The trucks sits as it did before and I've already ordered all the parts to replace the head gaskets/heads/water pump/timing belt, harmonic balancer/latest crank bol/all vacuum lines. Just have to find a weekend to do it
Goldenbora
