Isuzu NPS 300 camper build
westyss
roll up shutters was the route I was going to go with for my pass through too, I was looking at some roll ups off a fire truck and they are a much tighter fit and finish, looked good too but still has the cold issue even tho I think I saw somewhere that there is an insulated version, cant see that helping much if they are made from ally
4x4coaster
Finally, some pictures worth posting!
I still spend almost every weekend and a little time on it after work each night and I’m still amazed how long everything takes.
The water & grey tanks are finished; brackets, protective shields and even some left over heat insulation for the sides close to the exhaust, however I haven’t mounted them yet because they will just get in the way of other work for now.
Spare wheel carrier almost complete, but able to bolt the 2 spares on for a quick check. Rear bumper design well under way just need final drawings to get steel sheet laser cut & folded, then it is the wheel crane design & fabrication. I’ve got most of it sorted in my head, it is just down to execution details now.
I purchased 6 of the special wheel nuts to secure the ATW alloy wheels rather than make something, no point re-inventing the wheel-nuts!
Those of you familiar with the Isuzu tow-bar may notice mine is upside down, this is deliberate to increase ground clearance since it wont be used for towing often.
4x4coaster
finished building the house battery tray on locking slides.
Each battery weighs 45kgs so it is all heavy duty construction.
4x4coaster
It's about time I shared my build plans I guess, so, here it is;
I have engaged a company in Geelong called VMS (Vehicle Modification Specialists) to build the shell for me, then I will do the fit out to completion.
There is a slim chance it will start before Christmas but I'm not banking on it.
SkiFreak
Crazy Person
I wish I had CAD skills, tried google sketchup...
I have to admit, I started out using SketchUp but found it very limited, primarily because SketchUp is an architectural CAD package.
I now use Autodesk Inventor, which is an engineering CAD application. SolidWorks and Rhino are two other great engineering CAD packages.
But yes, you are correct in that it takes quite a bit of time and effort to get your head around any of these CAD packages. Personally, I think it was worth it, as I have used these skills for many other projects, not just my truck. It can also be a money saver, as you do not need to pay someone else to convert your plans into electronic form suitable for importation into CAM applications (used for things like laser cutting).
