Sold my Eagle, now what? (Bought a Trooper)
jeep-N-montero
I've also owned my share of vehicles. :) (I'm at about 25-30 at this point.) For me, early Montero's and Troopers are solid rigs and I have no real feedback on those.
The newer Montero's and Troopers 1995-2001 have some pretty clear differences.
Motor
1. Firstly, the 2001 trooper I have has a smooth, powerful, reliable timing belted, non-interference motor. The 3.5l sohc in Montero SR's are interference motors. Snap a belt, and there goes the neighborhood.
2. Montero motors have butterfly valves that can fail and basically turn the motor into a paperweight. No such failures occur with the trooper 3.2. or 3.5l motors
3. Both motors use oil. that's a wash. In the trooper it's improperly designed pistons, in the Montero, it's valve guide seals. Neither are a big issue if you keep eyes on levels.
4. Spark plug replacements on the Montero are ridiculously complicated. see this 6 part video for a taste of what's involved: https://www.youtube.com/watch?v=SMtWHiPnISY
The reasoning is that one can use lifetime plugs. The thing is with an oil-burner, I'm not okay with more than a 1-2 year plug change interval. Trooper plugs are $2.50 each, and installs are a non-issue.
Seating
1. Montero's are a 2 in front, 2 in back, 2 in 3rd row, if equipped, rig. I have 3 kids, which means that simply transporting my clan means that I lose my cargo space. The trooper has MUCH more headroom and shoulder room in the front, and in the 2nd row has more than enough room for 3 adults. The cargo area is boxy and cavernous. I've never once regretting not having the factory 3rd row seat.
2. the 60/40 reclining rear seats in the trooper are very useful for cargo carrying. I think the Montero rear seat is 50/50. might be a wash, but I remember them being more cumbersome.
Aftermarket
1. Aftermarket for both is nothing like a jeep or Toyota, but the trooper has locking hubs from warn, lifts from ARB/Calmini/independent4x, and bull bars and snorkels from ARB, too. I have yet to install a snorkel, but it's on my list along with a dust pre-cleaner to make sure my motor is breathing clean.
2. I didn't find the same type of support for the Montero from ARB when I was looking though other vendors might have popped up to fill those voids.
3. Parts are readily available for the trooper, and is a blend of Aisin, Isuzu, and Denso/GM parts. Very affordable. My rig has literally needed almost nothing as far as repairs, though I DID make an effort to research the parts I might need like starters, alternators, fuel pumps, bearings, axles etc. Montero parts are not super scarce, but my research resulted in parts that were more likely special order items, and at higher cost. This may just be my area or simply my experience and not the same for other owners.
Check out these two websites for info:
http://www.independent4x.com/Isuzu-Store_c_8.html
http://www.planetisuzoo.com/index.php?sid=3d3a87d038299c425ee8275d57c7e857
That's about all I have that I can remember that pushed me over towards the Isuzu lineup. I know a bunch of folks at my work who run Amigo's, Rodeo's and troopers and all report the same findings. Comfy, reliable, easy to work on, and a good value if you put minimal regular maintenance.
I would look around this site at my trooper build thread, as well Montero builds. There's quite a few troubleshooting threads about Montero's where lockers don't work, solonoids have failed, etc, etc.
The big weak point on the trooper is the oil consumption, and an auto tranny that can be troublesome, though mine is doing fine at 188,000 miles. If you want a 5 speed, the early Troopers are good to go with their 3.2l motors and strong 5speeds.
Okay, let me address a few things:
1. Many vehicles use an interference engine setup with a timing belt, a quality belt used at proper intervals eliminates any issue of engine damage, but some folks do not do things properly and the end result can be negative. Try to find a thread where someone lost their engine due to this on their Montero, it does not happen very often and is usually due to neglect.
2/3. Only the 3.5 DOHC Montero engine used butterfly valves and had oil issues, the 3.5 SOHC engine used 97-on was about the best you will find and do not have oil or butterfly issues.
4. I didn't really mind doing the spark plugs on mine when I bought it, the original iridium plugs I pulled out of it showed no fouling or oil residue after 155k miles, put it back together with new valve cover seals and is good for another 100k miles.
Seating:
1. Montero is a 2 front, 3 middle, and 2 rear setup that fold up out of the way, but most will remove the rear seats completely. I know of several guys over 6'4" tall who have no issues with front seat fitment. My dad who is 6'2" has ridden in the rear seats when they visit and has plenty of room. Rear cargo space allows for plenty of gear, if it doesn't fit you probably don't need it anyway.
2. Rear seats in the Monty are easily moved forward and can recline, and the entire seat setup front to rear can be laid flat to form a bed.
Aftermarket support is not vast for the Monty or Trooper, but with the Monty you can run 33in tires bone stock and junkyard gear swaps are plentiful and cheap, OME offers a great suspension upgrade for either rig. Manual hubs, bull bars, and a snorkel can all be had for the Monty.
I have never had an issue getting parts for the Monty whether it be from junkyards or online vendors, many of the sensors and engine parts are shared by a lot of other Mitsubishi vehicles.
As for the factory rear air locker "issues", 90% of the time it's due to lack of use by the previous owner(s) and is easy to troubleshoot simply by using it or cleaning the solenoid.
As far as axle strength goes, the Monty uses a 9.5in rear axle that very few people have managed to break even on 37's, it was over built and will last forever. The Trooper uses a slightly smaller rear axle but is still plenty strong for 33in tires. You can't really find many people who have ever had transmission issues with their Montero, they are amazingly reliable.
jeep-N-montero
LoL...oh, and EagleFreak...there's a very dedicated cadre of folks who LOVE their Montero's, so I'm sure this gentleman will have some good points to share.
And someone had a complete OME suspension setup sitting their garage for a Trooper until they decided to get a Montero instead after many hours of research. So yes, I do have some insight to share.
BIGdaddy
Thanks Brian, that was a pretty comprehensive post. Luckily I'm not in any hurry, so I'll do my due diligence while searching for the right rig for me.
Bill, honestly I've never been a fan of the Wranglers. I think it has something to do with my South Florida days and seeing morons cruise the beach in their Jeeps that would never see an unpaved road. Plus a buddy had a TJ and I felt so cramped in it, I couldn't wait to get out and the new ones are way out of the price range that I want to spend. I had an old 76 Cherokee for 6 months that needed quite a bit of work. However, in hindsight, if I would have spent the time, money and effort that I spent on the Eagle I just sold plus the money I lost on 87 Eagle that had the 5.3L and 35's , it would have been an awesome rig.
Yup, take your time. I test drove a lot of trucks before getting my trooper. First, second, second.5, and third gen montero's are all unique in their own way which is separate from the montero sport. I'd go sit in and try out all of them. Same with the trooper. 1st, 2nd gens are quite different. I'd go sit in a few fj60fj80/fj100's just for good measure.
Oh, and if space is a priority, it doesnt get much better than an awd/4x4 convert astro/safari van.
Cool rig. I had a J-truck for a while. Thing was a beast!
boxcar1
boxcar1
Once an AMC fan , always an AMC fan.
1st gen Troopers are great rigs BUT . If you have ever had to buy a new tranny for one you'd look harder at the Jeep.
A truly legendary rig.
It took me 4 years to build this one for my wife . Money and time well spent.
PirateMcGee
Might check the Montero Sport too. Better power to weight, lower factory gear ratio, better stock ground clearance, sportier handling on road, better gas mileage, more interior volume (with both having seats in). Trade off is slightly less payload...
BIGdaddy
Yup, my buddy LOVED his. Nary a problem. Sold it to buy a 2010 2wd prerunner tacoma. Go figure.
Eaglefreek
Eagleless
The Sport really wasn't on my radar, but looking at pics of "Montero Sport offroad" on Google sparked my interest a little bit. There are quite a few of them on Craigslist and usually at least one in the junkyard. However, I think the interior may be a little too small for me.
PirateMcGee
It has more cargo space than the full size (79.3 vs 67.1cuft)
Eaglefreek
Eagleless
Well, I drive by an auto repair shop every time I have to go into town and there's been a Trooper parked there for a couple years. Today I decided to go ask about it. It's an 88 with a 2.6L and an auto. The shop owner told me it was a customers and that he didn't want to spend the money to fix it. The head is off of it right now. He told me who it was and it turns out the owner of the Trooper is a good friend of my dad. I called him and made a deal. It has 168k miles and the interior is almost perfect. I'll have to trailer it home and get some pics in the next couple of days.
THIS IS NOT IT, but it looks exactly like this one. Same paint and wheels.
PPCLI_Jim
:bigbossHL::088: AHHH now IC the interest in my Trooper you want it for parts !!!Hands off by the time i am done with this I wont be able to afford it !
Eaglefreek
Eagleless
Maybe if it was closer.
I picked the Trooper up today. It was fun loading it up by myself. I couldn't find my darn come along, so I used a chain hoist to get it on the dolly.
Manual Hubs
I gave it a much needed bath.
I'll be installing the new engine at the shop at my work and getting in the shop was fun by myself, also. I used a winch we have on a cradle.
I'm picking up a wrecked one in the morning that the engine was just rebuilt a few thousand miles ago.
PPCLI_Jim
Nice that is in much better shape cosmetically then mine . I did manage to finish install of my winch ..so if you want to put one on mine is a pretty solid simple way to do it.
Eaglefreek
Eagleless
It's in fantastic shape. Not a spec of rust and interior is in great shape. I was worried I overpaid, but after cleaning it and finding out it had manual hubs and the Yakima roof rack and basket, I think I did ok at $700. I built a bumper for my Eagle and if I decide I want a winch up front I'll do something similar.
zhukoveli
