The Lunchbox Build... 4x4 chevy shorty van
Lunchbox2
hopefully the washers that push on the plastic bushing are better now. I had to make new ones, cause the old ones were bending in the center where the bolt pushes on them, I'd have to re-adjust them constantly because they would bend and loosen up, causing deathwobble. I made some new ones from cold rolled and havent had anymore problems.
That was one of the downsides of going with the less-expensive arms, the higher end ones don't have any bolts holding the kingpins, it's built-in to the arm. Hopefully they work out ok and I don't have any issues. I'll remember you said that though, if the front end starts to seem "loose".
V30CREWCAB
yeah it will start to get a wierd little shimmy when you hit a bump, and you know to tighten them. I just used some cold rolled flatbar and milled out two new washers for my truck.
Lunchbox2
As an FYI, an off-the-shelf dropped pitman arm for truck application worked on my stock van steering box.
I'll have to look into that again because you're the second vanner to bring that up.... I think my steering box is different from yours though, because I just can't see how a truck dropped pitman arm could work in any way?
Lunchbox2
I cut up the stock 2 1/4" y-pipe and re-welded it back together so it would fit between my spring brackets. Then I cut an exhaust off a truck in the junkyard to start making my tailpipe. I cut out the straight parts, and then cut out the bends in the pipe and started putting it all back-together. I think I can probably make it all the way out the back with what I have, and it was FREE, so money ahead there. I had to stop at the muffler because the welder wouldn't reach any farther, but at least I can fire it up now and not run open manifolds....
I also came home to find my studs for the high-steer kit in my mailbox! So I can FINALLY get my steering completed. I don't know how much I'll get done before the weekend though, as it's supposed to rain for a couple days and then get freezing *** cold.
QCAuto
very nice, only thing is id ditch the over length ubolts and bolt spacers unless theres some specific need for them?
Lunchbox2
I got u-bolts that are way too long, and they don't have threads running all of the way down so I couldn't just cut them down. I had to get it out of the shop so I cut up some DOM to act as a spacer until I can pick up some new ones. It won't be driven like that....
Lunchbox2
High steer is done. That went together pretty well, no big surprises. In all, I'm happy with the parts and can actually steer my van now! It's getting closer...
QCAuto
cool, just looked a little... u know.
looking good on the steering end alright!!
Vial Style
Yep. Your steering box is completely different, and I know mine is stock because I bought a reman for a 1979 G10 and it was exactly the same. I suppose they changed them over the years???
Lunchbox2
I'll go back over everything over the next week or two. A little trimming & grinding, add a gusset or two, just try to clean-up all the rough edges that still remain...
Lunchbox2
They changed to the newer style in 1983. I only know that because I was searching the different years on Oreilly auto parts website... lol
V45W_Proto2.5
