Hella performance 2.0 headlight bulbs (h13). A nice upgrade.
kojackJKU
Autism Family Travellers!
I just installed a set of hella performance 2.0s in my patriot. A noticeable increase in output and overall beam pattern. For the money, they are a nice upgrage for the H13 bulb. I put them right up there with the phillips xtreme powers I ran in my JK before the truck lites. A really good upgrade.
kojackJKU
I don't know if where they are pumping out a bit more light, the width seems better...could be that...but yes I agree the beam pattern should not have changed...wrong wording.
kojackJKU
Had the pat out last night for the first REAL test of the lights. THey are a major improvement over the stock bulbs. Cleaner light, if that's is a way to describe it. and just more overall light output. I am very pleased with these bulbs compared to the stock sylvanias.
Frank
I've read 50/50 mixed reviews on upgrading the bulbs. Most say go LED's, but they are 4-5x's more $$ depending on what you go with.
I think I will give the bulbs a shot. Anything better than original equipment is worth the $$ in my opinion.
kojackJKU
I would never put LED into a halogen housing. they work like crap in there. no distance in the beam at all.
AZJim
How long of a life are these bulbs supposed to have, usually upgraded bulbs only last a year or so. WJ's can be a pain because you have to be careful not to break the housing mounting tabs. But would sure like to have better lighting.
Jim
kojackJKU
They are rated at 140 hrs burn time. I am not sure how much you use the lights. But I guess they will last as long as the factory sylvanias.
