Added Center Jump Seat, 06 Savana AWD
simple
I added a center jump seat to our van so I could use a child's car seat between the front seats to save space in the back for camping etc. The seat I used is out of an F-150. The reason I chose this seat is because it has a factory integrated shoulder belt system. This seat is pretty wild with something like 6 cup holders, several compartments and 12v socket.
I fabricated some steel brackets that use the Savana's OEM front seat mounding hardware and the ford jump seats factory mounting holes.
Here is where I used the factory mounting hardware for the front and rear bracket. The steel L bracket is sandwiched between the nut and factory front seat base.
The seat in place.
riNR
I considered doing the exact same thing. Cool to see it done. I went with a fold down bench seat for knaps on the way back from windsurfing trips.
lseann
Here's a link I found for a company that makes a custom jump seat for the Express....way too expensive and I like the look of the F150 seat better btw. However,the install instructions are interesting and might give someone else an idea regarding how to attach the mounting bracket or whatever. https://www.cyclevan.com/seats.html
lseann
Especially like the part about the carpeted kick panel replacing the factory storage compartment on the hump for more leg room I assume.
02rangeredge
View attachment 326058View attachment 326059
View attachment 326062View attachment 326063
View attachment 326065View attachment 326066
The seat in place.
View attachment 326068View attachment 326069
out of curiosity where's the 12v on this seat? inside the armrest?
riNR
Do you have full welds on the under side of the angle iron to tube connection? Those short little tack welds are usually weak and don't have a lot of penetration to them. Just don't want to see that seat become a missile in a front crash scenario.
simple
Yep, was fully welded on bottom.
sunnyaz
