Discontinued Parts
latarheel
latarheel
anyone have any recommendations for finding AWR3287, a foam insulation piece found underneath the console for a D1 manual gearbox? Mine is missing and the usual sources (Rovers North) say it is discontinued. If I had a remnant from an old one as a template, I could fashion one out of heat reflective insulation but wanted to tap the collective knowledge base here for ideas or recommendations
Land Rover Parts International Shows both in stock. If it defaults to in-stock it might automatically send you the supersede PN as SMKsignals stated. Send them an email and you will get a fairly rapid response. I had to order a few parts from here that are hard to come by for my LR3. They source the parts globally to your closest location. Some of my stuff came from NY and a few parts from UK direct.
Hope this helps. Personally I would use the newer insulated aluminum like you stated though. Cheaper and probably much better than that generational part.
BTR8331
http://www.landroverpartsinternational.com/SearchResults.asp?Search=BTR8331
AWR3287
http://www.landroverpartsinternational.com/SearchResults.asp?Search=AWR3287
