Gen 2.5 - Sloppy Transfer Case Shifter/Engagement
All-Terrain
No Road Required
Shifting my Gen 2.5's transfer case lever is like stirring a pot full of thick lumpy stew.
It will engage all of its modes properly (2H, 4H, 4HLc, 4LLc), but sometimes it takes a few tries to find the mode you're looking for... And I believe that's why it sometimes takes a little longer to disengage a previous mode, because the engagement/shifter movement is not positive.
Any common remedies here? Are there bushings that may have been ground into a fine powder, or anything like that?
I'll definitely do a fluid change, because I don't know what brand or type of fluid is currently in the transfer case.
Thanks in advance!
nwoods
yeah, you got the disappearing red ball, and you need a white ball from a pre-98 model year transfer case shift lever.
All-Terrain
No Road Required
Update here - I did some searching around on the Internet, and found this link:
http://www2.pajeroclub.com.au/forum/showthread.php?t=28251
No need to replace the entire transfer case shift lever with an old used one with a white ball.
Instead, just buy the replacement bushing, and swap it in.
I ordered this exact part number, MD701605, and it arrived today --- cost me $22 shipped.
I'll install it hopefully this weekend, and will probably coat it with some white lithium grease or something similar.
jeep-N-montero
Except you are replacing the old crappy one with the same crappy part, it has been discussed before and you cannot buy the earlier/better part new anymore, good luck with the swap though.
Salonika
Monterror Pilot
Does this repair, no matter which way it's done, ever need to be done more than once? I guess it depends partially on how often you use this shifter, so for some people the bushing is a fine way to fix it.
Good work on finding the mitsubishi part number. However if you have access to a pick a part junkyard, the whole white ball assembly will cost you less than $20. I think I paid closer to $10.
All-Terrain
No Road Required
Well, when we bought a brand new Montero (Pajero, actually, since we were overseas) in 1993, it worked great as I recall, but it has been too long for me to be able to remember what it felt like when shifting the TC lever.
I don't know how a Gen 2.5 felt in comparison when new to the new white ball shifter in a Gen 2.
But, I'm willing to bet that a now 17 year old Gen 2.5 with a brand new crappy piece of **** don't-ever-buy-one bushing will feel pretty decent. Pretty subjective topic, anyway.
Hard to take your comment seriously when you're selling old junkyard white ball shifters for $75. Not exactly unbiased.
Oh well.
All-Terrain
No Road Required
I don't have a Mitsubishi dealer nearby, but apparently these bushings are only $5 or $6 new. I had to pay $16 for UPS to bring it to me.
iStan814
