Not sure on the gasser, I thought they originally ran off the distributer. Did you put in a diesel gauge cluster? Mine was an idi and already had a Hall effect sensor on the injection pump gear which has 106 teeth, since that spins with the cam at half crank speed it makes the tone wheel on the crank need 53 teeth.Hi BFDiesel,
How did you determine that the tone wheel had 5 too many teeth? I have the same wheel on my 93 that came with a gasser and I always felt that the rpm read higher than it should be, do I need to do this as well?
Thanks for your input and keep up the nice build.
Eldgen.
