Wheel Size Fits? - 17x8 with 0 offset -
TerrenceLP
Hello,
After searching zero or 0 offset I still can't see what any issues would be -
2005 Montero Limited - How much offset is too much for a 17x8 rim? Tires will be a 285/70-17 Bfg-ko2
The fit needs to functional in that can't hit out side fenders.
TerrenceLP
UPDATE - Ended up going with this set up.
Level 8 PUNCH wheels 17x8.5 +18 @25.5 lbs Per
Hankook dynapro atm rf10 P265/70-17R
Lift is next - Medium Old Man EMU Springs with Bilstein 4600 Series Shocks - should be awesome!
XQG_juRUfCjbkJ6wE9ZFcZewz90W_RQ2pmfUHQl6lmzRSDEGLzPKXNktmQVH_HmkBw6HKbHfFd4tIbAgVX9gsnWI9_pZtTg08sXHLvNsWjJcuBfyknyX6DvRlXBTHVdGMFClUTEaMCw3XOTHV0qNyoBSsTKOkLNzdsafiWaxnxcVlrhTqwiWEfuvGPy7yIky8aDMtRerRjo0IjBvmBHBEdHVFvOyGzlpC-ba0bnvI0uP7wEm7Wnlxd1CGDl-zxqZS7SFi7FhXI8gTp_fY88bKcyVcWZ7kVVqvtPTwT0FmOOX_m5Ccu8Zlq3o8JNt9Oh91OUgfwx91gVo1dK0MT0ZIK34Fs5TXqEEOiSIw9PaniPmMHmp0COXoIutN7AgnzlLuVhKHH49l-vkQF4bvj-Vq1jE1uBncN2p7dOdKfS1YwJfknnMqI41lKnX71l8fiuna900RDivjtcfqhnbR4wEtADGz66eJODA4fwWR8q74yjzbys-cFBf4jC58V0Zqxwa-IOLR8WEAoYaIcWrgm1Amw-xbq5McQ_JhgO-n4CYTIu3DNT7ZioJ8u9FOgKlYQ2TXZ12=w1727-h971-no
to this
http://lh3.googleusercontent.com/G18r7Wd4YLpP_Acv4QQuHKe8GPnsF_gveYGtlnbO-hdhg28TjYcZd3mEXGFy6vyeuMh1n_nERyrbeOnyQ37r_QAoiUf_l2e4cXtJywCXC7yOs4UAVpHHRwW_LxKngh2UW_rCKd-95cPulmghLnN2v0mjdAfcW7lGr5zbsMi3oLjPpmVeKO2y9jYBR4MEb1wlqocnMk8OdLFig5pMlmn7vRxG8wpNyidUZMIyNfpoCwLkQbieN6d5QdnEnk48h9F2II6Pmu8ta-iiZNVBI6WWic8295NUnrs70W3IUEWTGM-wVy3RKhwOSw8gHCcyuUrMn3mqTmprrzxUjhXWIHPAcEr_scmk2f-I5r5w1bx0GU1NNFMgR0HWiziXvF1uGKhBdziIgicbITJw3yw_vQQ3YShIYJkuL5vohtjOOmpgYKb3AfT8pdQIyrBdub07W0nHXtGHgkcAWhUt6ReY_N2yqIiAEMviDi8Nf8e-****-3_aE84o-6pTfsNY-vm4VbHzGbHcsmFuJR_QjTCxn7PWqyyOlvaoUoIZ-EHXbt1bzIXYyP8K2ZiGq2ynGfCUeCU7iNvNzd=w1727-h971-no
FullMonte
Alright, so with trial by fire, I found out that 0 mm offset wheels do not work. I found out by ordering five 17x8 steel wheels off ebay and they sent me a -12offset. I sent those back and had the shop order me some soft 8 17x8 steel wheels with 0mm offset. At first, I thought they would worked, I was so excited until when backing up the wheel clipped off something from by break caliper. I have to go to the shop tomorrow.
So, luckily the shop had four 17x9 18+offset wheels. And here they are. I have some Cooper STT Pros 295/70 r17 33.45" Finally! I could breathe a little better now.. I hope this helps anybody looking into 0mm offset.
Sent from my SM-N900P using Tapatalk
Toasty
There's also style of wheel to consider, I should try my -12mm wheels on my Gen 3.
AZXPLOR
