Guess my back order of one month for the fronts isn't gonna take a month lol. It just shipped today. I barely ordered them too. Woot!!
Got the rears installed. Feels a little firmer but I also don't have any weight in the rear. Not a direct fit so you either have to widen the lower shock mount or grind down the lower shock sleeve. I widen mine and it wasn't hard but took a little time. Bent the bolt I used to widen it but it was the only one I had that was thread all the way. I also had to rechase the threads before widen the second side.
If you never taken the rear shocks off. The lower nut is actually a locking nut seen in photos with 4 lines on it. You loosen the bolt side to remove it not the nut.
Couldn't fully flex it out. The front tires started to go down the ramp. Gonna see if my buddy with a fork lift will lift it lol.
