UJOR Build Thread
bknudtsen
Chris, did I read or see it in one of your videos that you can not install the rear spring bushing for the front springs beforehand like you can the front spring hangars?
Thanks
Correct. You have to pull the OEM suspension brackets on the frame to access the spot where the rear bushing sleeve goes.
ujoint
Supporting Sponsor
Thanks
You can install the front spring hangers, just can't cut & weld the shackle sleeves until the front suspension is gone.
fielder441
Monday! SMB on the rack for ball joints & wheel bearings.
Took the kids out for the weekend, had a good time even though they wore me out big time. I left the trailer there to make life easier, went back to grab it this am. Lucky that we live in such a gorgeous area.
I don't normally post family stuff here but here are the mutts! And now you know why I was worn out. The boys are a bit crazy right now.
We are going to try and take the triplets out for the first time camping in a few weeks. I'm sure it will be an experience...
fielder441
Mobile is an understatement! They are all running, climbing and daring each other to climb this and jump off that. They are 16 months now. Been a long but fast 16 months for sure.
ujoint
Supporting Sponsor
Soft tear down for this 2010 V10 that has 1700 miles on it! Big build coming up. High top, 6", bumpers, lots & lots of parts being added before it heads off to SMB TX for a full interior.
ujoint
Supporting Sponsor
Another big build about to head home! I screwed up during my walk around, van has an ARB rear diff not a True Trac. 08 E350 6.0, 6" lift, Stage 2 front axle with RSC and 4.56s, Sterling 10.5 rear with an ARB, UJ OBA system, rear skid, Balck Rock wheels, Toyo 35/12.50/17 RTs, NV271, 1350CV shafts f/r, Aluminess bumpers, Warn VR12000 winch, Sienna seats, Rock Slide engineering steps, Flares, Rhino on the rockers, full 6.0 upgrade, undercoated body, etc etc.
darrylkd
