AEV Savegre Wheels and Dexter Hubs
Johnnyenglish
Can anyone tell me what they had to do to get the AEV Savegre wheels to work with the Dexter hub with electric brakes? I am about to order a new axle for my M101a3 and I remember seeing someone using a spacer to get the wheel to fit. I've looked and can't find the solution anywhere. Any help would be appreciated.
John
Martyn
You are going to need to run 2" adapters to accommodate the small center bore of the AEV wheel.
Call us if you need custom adapters.
dstock
Product Name Part No. Quantity Item Price Total Price
5 X 5.00 to 5 X 5.00 Wheel Spacer
Configuration: ST12X200
Adapter Thickness: 2.00" Thick (50.8 mm)
Year/Make/Model of Vehicle?: 1953 M101A1
Would you like a Stud upgrade? **Note, you can only purchase a stud upgrade if your adapter thickness is 1.0 inch or larger.: 1/2-20 Stud
Center hole size was 2.67"
jwilson2598
I'm late to the party, but as Martyn said, you will need spacers to fit them. I have AEV Pintlers on mine and the Adapt-it USA spacers work perfect.
zhukoveli
