NEW RIG: 2012 F-150 FX4
D45
I am at the 6,000 miles marker right now, on my current oil/filter
For under $40, I will change it every 6k
D45
Any calibration need to be done when swapping in new rims, that have new TPMS sensors? Or will they "learn" PS settings once it's driven a few miles?
LWD601
As far as cold air intakes go. I'm gonna have to argue a little. Yeah there are a lot of them out there that do nothing other than look good. But AFE's intake made a noticeable difference on my truck. It uses the factory air box so intake temp is the same as factory but doubles the intake flow. I got mine for free off of a trade in at work so I didn't mind one bit testing out a $500 intake for free even being skeptical. But seriously it added some good acceleration to the truck. That being said a lot of what other people said is going to give you more benefit for what you spend on it so I wouldn't make the intake your top priority
155mm
You'll probably need to reset the sensors. You can enter a TPMS reset mode and go around with a speaker magnet or something similar to each wheel. If the procedure isn't in the manual, it's definitely published on the internet.
D45
Well I believe I found some Raptor take offs, with only 8,000 miles on them.............from a 2014 Raptor
Not a fan of the BFG AT KOs, but they will work for a few years
Hopefully have them bought and installed within 3 weeks
D45
Still searching for tires and wheels, all the good deals fall through
I know the 17x8.5 Raptor rims have around 6" backspacing...........how far out would 17x8.5 wheels with 4.75" backspacing be?
D45
The FX4 OFFROAD decal on both sides of the bed were distracting with the blue theme
So, they were removed
D45
So, I then started on the three amber LED grill light bracket, aka Raptor style grill lights........For $50, its a cool cheap upgrade
I got it wired and soldered up, mounted and the wired ran into the cab
Just need to find a good 12V accessory tap tomorrow
D45
All done......looks bright from the pics, but it very closely matched the other amber parking lights, side marker lights, and the mirror amber lights
D45
Here's another option for you. These are for sale in Merriville, found them on CL.
I talked with this guy, since the 18s are growing on me..........
He ran these on his truck, with a leveling kit
305/70R18s rubbed
He switched to 305/65R18s, which cleared fine
305/70R18: 34.8" x 12"
305/65R18: 33.6" x 12"
275/65R18: 32.1" x 10.80"
275/70R18: 33.2" x 10.80"
285/65R18: 32.6" x 11.20"
295/65R18: 33.1" x 11.6"
Again, my current setup:
275/65R20: 34" x 10.50"
I do not want a smaller tire, I would be happy with a 34" tall, but wider like a 12.50"
fnjeep314
Here is when I picked up the Raptor wheels and tires. $1k for them with only 1K miles on them.
lpSKbYvGkZehnbbURy7gQHy5gBUr7MBGLzdtGNPmxgtLa6CLIQ8k5Zv5zih4ApizNkxPXChxP-Ru3iGvuii9xQzHlkiiujsZ-4otcyhVdax3vNj9viVRe7pnitSI_krAVghgs49Kdp9QTuxxZmQgWhHF-K6MXK9oyttylVgIhPdRzmKl5VXpQtYvAahamoki5vEs9ZxqgOB3Tm9ntQ0aUTXDqIV_0hIV6j13-yfBaxOv6NWDw7lvLsEa4SzzNHZYJgUBk8cCVry47qj4w550LhPSlxSZtZgF82hef2lB56lNZQutvmLkUGIW0jpJ7rrjxjPDyNey7s1NVBg0Kd2nDjawgq_yxcKpK1nDCux8jSLlXG4_7tduTkvAvYw7aB-HNyIrjmVd3d2ZPoHz59UR5KkQe-Nc_ODAiLvkyVDpK5MOZ-sM36vXJCEqoSGjWLblhCJrlNlW9Rlaw76YMEz24C0ac9XaH3A6QUVjeV_6wZswNTv-K8_BNglj83OGbGkcotM7mhmYD6DMO-Ump_XmWv67LmKLdeVGlGvenoFOhdpVa_NI96s6OkBJypwpJhmtQXPZmyqoA_yfV3H6Nf_1tzatmHWJPck=w1247-h705-no
Here is how my truck sits now. I have Fox 2.5 remote res front shocks, Icon UCA, ProComp AAL with Raptor rear blocks and Raptor rear Fox shocks, Synergy 1in lowering rear shackles. Perf wise I have a Full Race front mount intercooler, Airraid intake and y pipe, convert to single BOV running a Tial Q 50mm, Heartthrob exhaust, Solo catted DP's, Livewire TS with 5* tuning, Leer topper, and a G2 diff cover for a little protection. I also(like the OP) had to make sure that I upgraded to the OEM HID's. What an improvement over the halogen lights.
vmvwf19v2fKqdIaxZwl7Xdz1TtRzZXvNwIoXrDkSzgi0Ws_o6uajCSCd1i5CZUUFWAv-R9J5Mse9b_YJi4K2ZgVEW391vIFGk03iIdXhbEF3cDJWjiVHm8ZN7r_s83_xcrrBOiimCmgOhz8lp3Lz-NkJMyvtaJGFNq1EpO6kjkkkMsgnDpRylN32WubkMLC-Ir_zBIbTYk12dyhROclqTQn97iZRNE1ffbahyBmIU-0A0ep7tiPrfqSr6TeWGJoeN9rv89jOINOKodgN7XQ6RJRVhOl603DOqlMVLiU1mQ1TmNcwFo7tpXZFQ9AODIML2Z1bNcxVx9L9Sz3JrDguoHNJzb-99duCFaFx1fccn6P1_1B21z8W_JQ8LwNqGz2fTbUiM3x1g_TxDwyuGbrG4jrpNdGxtxp4Jm6q17E1FenYB5dpwzXRQ0Llui3CfoeFR-sJ_rY-PFDEpNjznVLcUWF2VIFqcmDR9fxZGpR0Chhy1fc04EOgoDOPvQoRXMDGO0RAFGW-unqg_96oTcm1dl7XOSue6-MhpH_-GGQlWDZ7pJ5oqpP_hp-Jf5BQ2uSdCZCWZpMcahxv69LMB936Smwocsaf9SU=w940-h705-no
I will say that the person who said they are only getting 13mpg, something doesnt add up. Even in my configuration I am getting 15-16mpg city and 17-18mpg highway, and thats with me having transmission issues(Im pretty sure, but maybe the turbo's).
V45W_Proto2.5
