Adventurous
So the addition of the Prinsu rack meant that I had to re-think/re-work the awning brackets I had previously fabricated. Oh well, I wasn't too attached to those ones anyway as they looked sloppy and I just couldn't have that.
The Prinsu rack uses 80/20 extrusions which are perfect for the insertion of carriage bolts. I whipped up 3 brackets as such that utilize 4 1/4-20 carriage bolts to affix it to the rails, and 4 6mm bolts to affix the awning. Each bracket is made from 3" x 3" .250 angle iron so I am not that concerned about fatigue or overloading. They should be stout enough by themselves. The shake test reaffirms this.
	 IMG_1266 by Tim Souza, on Flickr
And a side shot. Tucked a lot closer to the truck to minimize the potential for ripping the thing off. The aluminum extrusion backer is in line with the top of the roof rack rails over both the topper and the cab.
	 IMG_1267 by Tim Souza, on Flickr
Clean.
	 IMG_1265 by Tim Souza, on Flickr
Going to have to do a test setup. I purchased the walls the other day so the wife and I can have an enclosed space for privacy sake. Something about her wanting to answer the call of nature in peace. I shall therefore declare the awning roof to be named, "The Dutch Oven."
IMG_1266 by Tim Souza, on FlickrAnd a side shot. Tucked a lot closer to the truck to minimize the potential for ripping the thing off. The aluminum extrusion backer is in line with the top of the roof rack rails over both the topper and the cab.
IMG_1267 by Tim Souza, on FlickrClean.
IMG_1265 by Tim Souza, on FlickrGoing to have to do a test setup. I purchased the walls the other day so the wife and I can have an enclosed space for privacy sake. Something about her wanting to answer the call of nature in peace. I shall therefore declare the awning roof to be named, "The Dutch Oven."
