2000 Tundra "catch and release" expo rig
busmup808
I just converted the 2nd row Captain to the 60/40 bench. I am only asking you because modifications come 2nd nature for you. It came from a 07 Limited and Is oak leather in color. Comes with the center console between the seats
busmup808
Some pix of the seat and console
Sent from my SM-G900V using Tapatalk
Sal R.
Yes. No difference
That's what I figured. Thanks for the input. Now to source the parts!
Additionally, there was no mention of new brake lines. I assume the existing brake lines will work with the WH calipers?
Thanks!
D
Deleted member 9101
Guest
So, most guys with Tundras do the Tundra 231mm brake upgrade, but this one will be a little different.
I recently torn down a 4th gen 4runner IFS system. So, these are off of a 07 4th gen Sport Edition model. They will ONLY work with 17" wheels and grinding is required as well as 1.25" wheel spacers. But, the rotors are 338mm in diameter and the calipers are 13WH calipers and are also 231mm.
Sooooo, sis you have to use the spacers because of your rims? Did you need the spacers because the caliper hits the back side of your spokes, or the rim its self?
I have the "fat six" 20"s and am curios if I would have any fitment problems. When I eyeball it, it looks like I have a ton of room to work with.
GTV
The 338mm rotors were used with 18" wheels from the factory, so unless you are using 18's (or larger) then you'll need spacers so the calipers clear the hoops. 16" wheels will not fit at all. Your 20's will be fine.
At least that's how I understand it.
I asked about the MC as well, never got a response. I guess he never did the swap, it probably wasn't needed.
D
Deleted member 9101
Guest
Ok, thank you. Much appreciated.
Psyph
