Mitsubishi Montero JDM Clear turn signal - plugs
raysobi
Hello all, I finally got my shipment and my clear turn signal fits perfectly.
However, the plug from the original turn signal had only one input vs two inputs from the JDM piece.
(Even when I tried to plug, none were compatible)
Anyone had done this before in the past? Comments and pointers are welcome.
Sent from my HTC One_M8 using Tapatalk
JamesW
The JDM ones have a dual filament bulb like a brake/tail light bulb in the side light, when you indicate it puts on the brighter light to light up the direction you're going in.
I doubt that function will work on the US models, but you might be able to use the same plug that the tail light uses for the side light, and the same one the indicators use at the back for the indicators.
Sent from my ONE A2003 using Tapatalk
raysobi
Thanks James, I will give it a try. I saw coople guys here in the US did a conversion but don't remember who.
Toasty
I did it like 10 years ago, i don't remember what i did but i took down the inner fender and wired it up so all the lights (including fender side markers) worked properly. It can't be too hard if i figured it out.
DFWSFO
