I actually use rods and GAP together, just in the opposite direction. I put the rods in then recalibrated back down to run as close to the original normal ride height as possible. Then set up a memory slot on GAP for off-roading at the height that the rods would do normally without the recalibration.
Look really nice. What height is the suspension in that pick?
Thanks. This is sitting at normal driving height.
Normal height with rods installed, which is closer to off-road height with no rods installed , right
Switch out your tires?
Your roof rack looks different than picks on FRs website.
I run the green oval rods which allows me to run stock height/settings until I need a lift. It does require manually moving the rods into the "lift" position which takes about 3-5 min at the trail head but since our LR4 is my wife's DD it works for us.
