2 Land Rover Discos for sale
garrettjmu
Selling both the Land Rovers! Feel free to share. White one - $3,250 obo and black one $5,000 obo. OR buy them both for $7,500.
1995 Land Rover Discovery (White Land Rover)- $3,250 obo
- Alpine White Exterior
- Tan Leather interior
- 3.9L V8
- 4WD with lockable diffs
- 135,000 miles
- Fully loaded
- Automatic Transmission
Features:
- Heated front seats
- 2 sunroofs
- Roof rack system with under storage
- Trailer hitch
- Power windows and heated mirrors
- A/C and heat (which work great!)
- Limited Slip Differential
- Upgraded speakers
Recent Maintenance:
- Brakes bled
- Tires rotated
- Oil changed
- 8 new NGK plugs
- 8 new OEM wires
- New battery
Needs/issues:
- Front windshield has a crack in it
- Sometimes it takes a few times to start (never had an issue)
- Tires in the near future
- Passenger fender could be replaced (I may do that if I can find one localish)... just some scuff marks and a CB antenna mount drilled through.
- Car sat over the summer, currently not starting due to a rodent chewing through the injector pigtails (this will be fixed before selling) FIXED
This is a great car. Gets ~15mpg. I bought it as a winter beater and ended up keeping it for a little longer because I was enjoying it so much. In the little time that I owned it I took it out on the beach in the OBX, all over the place in the snow and multiple other trips to WV, NC, DC and over VA.
Car is paid for clean title in hand.
_____________________________________________________
1995 Land Rover Discovery (Black Land Rover)
- Black Exterior
- Tan Leather interior (rough condition) with Gander mountain seat covers on all seats
- 3.9L V8
- 175,000 miles
Features:
- 2" Terrafirma lift with +2 shocks
- Lower shock mounts front and back
- 100% brand new brake system. I bought the vehicle with brake issues and have replaced everything from the brake booster to the pads with extended SS braided lines
- Trailer hitch
- Terrafirma adjustable pan hard rod in front
- Terrafirma cranked rear arms
- Flow-Flex Poly bump stops front and rear
- Terrafirma tie rod bar
- Newly rebuilt double carbon front propshaft and rear u joint propshaft (not installed but included)
- reManteca Skid plate front
- Land Rover Defender wheels wrapped in 5 brand new Fierce Attitude tires
- Safety Devices Safari roof rack (Lightforce Blitz lights can be included for the front)
- Hi-jack lift mounted to rack as well
- Land Rover cover for rear wheel mount
- Land Rover rear ladder
- Asfir winch bumper with heavy duty swivel shackles. Also have a Warn XD9000 winch with synthetic line
- Land Rover all weather mats
- Sony headunit to replace stock one (needs to be wired)
- So many extras included. Boxes upon boxes in the trunk and rear seat
- Brand new heads will be included as well (they are still in wrapping
- Brand new Discovery II exhaust included
Recently replaced:
- Brake booster
- Brake pads
- Brake rotors
- Master Cylinder
- New transmission put in
- Transfer case corrected
Needs/issues:
- Front windows aren't rolling down
- Brake booster should be removed and have RTV applied. It has a slight vacuum leak there
- Radio needs to be hooked up
- Has a high idle issue, only when in park. Once it gets in drive or reverse there is no issue
- Brakes are currently locking up. Not sure what is going on with that but I'll have this (hopefully) sorted out before sale
This is a awesome vehicle. For those that know I picked it up from SC as a project car since it "only" needed a transmission. It has been an ongoing project and I don't have time to push forward with it anymore. I was originally going to remove the parts from the black LR to the white one but ran out of time this winter.
Any questions holler!
Pictures can be seen here: I'll take some more detailed shots this week.
https://www.facebook.com/garrett.hughes3/posts/10154476535049289
garrettjmu
Worked on the white Land Rover this weekend. Running perfect now. 8 new spark plugs, 8 new wires, two soldered pigtails and a new battery. Cleared the codes and have had nothing come back on!
garrettjmu
ALSO black LR fixed the locked up brakes. On the white one I just put in 8 new plugs, 8 new plug wires, new battery and 2 new injector pigtails!
