Truck/Marine/2-Way Compressor Fridge vs Portable Compressor Fridge for Travel Trailer
BSLemoine
Hi, everyone. I'm having a 1977 Serro Scotty Highlander rebuilt to pull with my 2013 Nissan Rogue, and making decisions about how to wire and run electronics.
(Before we start about towing weights, the SL is rated to tow 1500lb, the Scotty will be around 1100-1200lb)
Long term, the plan is to have it run off solar. I'm trying to build a system that has low power-draw refrigeration without propane, so that I can set it up for solar eventually, but for now, I just need the fridge to easily transfer between the 12V car battery when driving and the mains at the campsite.
The research I've done over the past month suggests that Portable Compressor Fridges are a great option (ARB, Engel and Dometic models seems to be popular favorites), but I've also just discovered "two-way" (12VDC/120VAC) Compressor Fridges that are marketed for Semi-Trailer Truck and Boat use. They typically have the appearance of a front-open mini-fridge, but there do seem to be under-counter drawer models as well. Specs seem to be similar for models with the same capacity, for example: Dometic lists the CFX-50 Portable Fridge as running an Average Power Consumption of 45 watts, while the CR-50 Truck Fridge is 40 watts. They seem to cost and weigh about the same. The Portable Fridge is about 33% larger than the Truck Fridge.
1. Has anyone had experience using the truck or marine model for car or rv use? Is there any reason not to choose the Truck Fridge style 12VDC/120VAC aside from portability? For instance, will I notice such a huge spike in power draw from the front-open door (if I chose that model), making boondocking with solar impractical for a travel trailer and CSUV sized rig (size and weight of panels needed)? Do they make a lot more noise, or give off more heat?
2. Considering that this is for a travel trailer, is it safe/will the power be sufficient to run one of these fridges from the car battery cigarette plug (15-20ft to the trailer) or do I need a leisure battery now, before I get to solar panels?
The next step is to build a litium ion battery bank system and then add solar panels, so I'm sure I'll be back on the forum! Any suggestions about how to proceed with the whole project are welcome! Thanks!
Ben
Stumpalump
The ARB fridge is 120/12v as well. All the fridges you named will work so I'd choose based on size, compressor vent location and how you want it to open so you won't have to move it to use it. Measure carefully and buy based on fitment and yes you need plenty of battery. They shut off real quick when the batts are not near full. Pre chill it and your food for days on 120v to save juice and to stop the fridge from freezing food that touches the sides. The small fridges do not circulate air so cooling can be uneven if you throw a bunch of food in a warm fridge.
4x4junkie
You will need to make yourself a large gauge extension cord to run it that distance, but it can be done (I've run my Edgestar 43qt out at the end of 20' of 12AWG... Not ideal, but it did work w/o giving me a low-voltage warning). 20' of 10AWG should work fine . Though if the plan is to give the trailer it's own battery and solar, I'd probably just do that rather than mess around with a big fat 12V extension cord.
Can't comment on the portable vs truck fridge, though something to keep in mind is cold air will spill out when you open the door of a vertical fridge. Might not matter too much if you only do it on occasion (most of the "cold" is in the fridge's contents, not the air), however if you do it repeatedly (like while in the midst of preparing dinner, etc.) it still can significantly drive up it's power consumption.
Petersmithinak
