1971 K5 blazer build
Mag71
So I bought a 1971 k5 while I was stationed out in California while I was going through a divorce. I was stupid to get married but the best thing that came out of it was my k5 lol. I payed 5,000 for it, and I know that sounds like a lot of money for the shape it looks to be in. It has a crappy 6 inch block lift in the rear and lift springs in the front. The shocks are rancho, so its safe to assume its a cheap rancho lift and believe me it rides like one.... It will throw you around like a rag doll if your not holding on. Its pretty stock besides tires and lift, 350 SBC, SM 465, and NP 205. 14Bolt SF rear and Dana 44 front. the drivetrain is very good except for the clutch, but I'm about to replace that.
Here's some pictures of the build so far that just started today.I will add that the body panels are all original and the largest rust spot is the size of a half dollar behind the wheel well. My overall plan for this build is to make a super capable rig that looks great but also is very functional.I would love to make an off-road swing out tire carrier that doubles as a stand for a gas stove, A winch bumper for the front and make some sliders to protect the door and body. and would prefer some storage option with drawers but we'll see.
After looking at the general state of the frame it looks pretty good for its age, but I am still going to take the body off the frame and sandblast it all down and put a thick coat of POR-15 on it to help prevent rust. This ins't first time me and my father have restored a vehicle and the first was much harder and a lot more complex 58 Cadillac's are long and have lots to fix....
My vision is currently a 2-3 inch lift with lots of down travel in the springs and obviously a shackle flip in the rear instead of blocks. New shocks all around, either billistien or fox I haven't decided yet. I've been referred to alcan springs for the new lift springs, and I will probably use the ORD shackle flip kit. As far as traction goes, there isn't a lot of locker options for the 14 bolt semi-floater axle and frankly I don't feel like putting any money into it. I may put a lunchbox locker in the front since I can just unlock the manual hubs and won't have any bad road manners while they are unlocked.
I would love a family roll cage for safety and also it adds a lot of support for the body, Blazers have a huge problem with the body panels not lining up while flexing and doors shutting or opening and I know this will help with the issue if not solve it completely.
While the body is off I will also weld in another crossmember or two.
Currently the old 350 in it seems very responsive and peppy it averages about 10MPG no matter what I'm doing or how I'm driving, and trust me I know 10 MPG isn't very "Overlandish" but I will work with what I have for now. If the the 350 goes I will just put in a 5.3 since its fuel injected and will hopefully boost my MPG to a minimum of 15MPG. The transmission shifts great and is bulletproof, but the clutch needs replaced as there is hardly any break from the clutch being fully engaged to disengaged. The NP205 has a very lackluster 2:1 ratio in 4low so the only option for that is to do a NP203/205 doubler which would get me to 4:1 in low, but this isn't a big deal right now, I'm not building it as a crawler as I have a jeep cherokee for that. As far as gear ratio's go, I have 3.73 in the axles and will probably keep them because I don't want to put money into a 3/4 and 1/2 ton axle. and it goes good on the highway.
This is my first build using a forum and sharing so hopefully its not too thrown together... any helpful tips or tricks would be appreciated.
I pulled off the bumpers today, the front wasn't too bad, but the rear was bad because the bolt head stripped out of the bumper and the whole bolt was turning, I sawed one off and managed to hold the other with a 1/2 wrench and back it off. I then sprayed down every single bolt,bushing and body mount with some penetrating oil.
chilliwak
Welcome to the site Mag and thanks for posting pics of your fantastic K5. Now thats a cool rig. I wish i had one. Cheers, Chilli.:)
Mag71
Thanks guys, I'm trying to upload some more pictures but I can't post links from my photo bucket yet apparently or don't have permission. Today if I can motivate myself to do so I will take more of the trim off as well as maybe start tackling the suspension.
borison
Love these blazers sooooo much. Best GM body style ever. Looking forward to your build. Keep us posted. I often daydream about owning one of these rigs and the toughest choice is choosing, pickup, suburban or blazer.
Mag71
Yeah man, I have a truck C-10 shortbed also, fleetside and has a 406 small block and turbo 350 transmission. It will go. My cousin has a 1972 K5 blazer as well but he's keeping his stock.
Mag71
As soon as the first comes around I plan to purchase this kit. The only drawback is the fact I have to swap from a 4WD steering box to a 2WD, but It's not really a big deal since I'm pretty sure mine is leaking from the sector shaft and I can't use it anyway.
I've always wanted to go crossover steering since its a benefit over stock in almost every way, The stock 4WD steering set up that has a linkage from the pitman arm to the drivers side knuckle and then a tierod set up from driver to passenger knuckle. In short it sucks, It has very poor leverage and often times wont even turn your tires if you are bound up in anyway. So the crossover will be a great set up.
Here's a picture of the shackle flip kit that I want to go with It will get me the lift I want with much softer leafs in the rear and get rid of the stupid block lift.
Anyways, I will update some more later.
Mag71
And some more pictures of the lift and just around the truck some more
I know, it needs to be cleaned out,
chilliwak
Thanks for posting those pics Mag. I think you might need to replace those blocks:Wow1: in your rear suspension. Look into BDS suspension. They make lift springs with a big arc so you can delete the blocks. They have the best garantee in the business and they are reasonably priced. Cheers, Chilli..:)
locrwln
Nice looking Blazer. As others have said, Chevy got it right the first time on those. If you are keeping the D44 front, I'm not so sure I would get rid of the SF14 rear axle (nice balance). They are very tough and Eaton makes an E-Locker for them. Saves a ton of weight and ground clearance over a FF14 bolt.
Also, is the SPID sticker still in the glovebox? I love seeing what options they left the factory with.
Looking forward to the build.
Jack
Mag71
Yeah man, I am going to lower the blazer to a modest 2-3 inches of lift. I feel like better springs with less arch will ride much better and should also let the axle droop more with a shackle flip. The shackle flip should put the springs pretty close to a zero arch spring.
Mag71
Jack
Yes the SPID sticker is still in the glove box, I'll take a picture for you when I can this evening and post it! It's a pretty basic truck with not many options. It was originally yellow with a white top, and came with the back seat, manual trans and manual hubs... etc.
I'm glad to hear that about the SF14 rear axle. I know its a 9.5" ring gear unlike the FF14 10.5" I know its not preferred if your rock crawling on 42's but that's not what this build will be doing. I think the weakest part of the Semi-float axle is that it's a C-clip design. IF you break an axle it will slide out, but I don't see myself being that aggressive with this truck at all! Plus I'm very experienced in all types of terrain and very rarely go heavy on the skinny pedal.
As of right now I am NOT planning on moving to one ton axles. If I break axles more than once or twice I may re-think that idea, but for this build I feel like the 44 and SF14 will do fine. I will have to look into the eaton E-locker because I've always heard great things about them!
Thanks for your interest!
Martinjmpr
Wiffleball Batter
Yep, that was a true classic design, my absolute favorite.
I had a '71 from 1983 - 85:
chilliwak
I like the arc in my springs. Gives a better ride in my opinion: shackel flip or not. The front springs with the staight or reverse arc are a real design flaw in my opinon. I might be wrong but the springier ride just suits me better. BDS does a 2 inch lift for the fronts that give you just enough arc to feel good. Not too crazy but in my opinion a world of differance. Just my 2 bits. Cheers, Chilli.:)
