NorthstarTC650-n-Tundra
zidaro
Love the thread, and set up Thanks for keeping it updated. I just got a promotion and am looking forward to a northstar pop up in my future. It looks like you have rotopax installed on the front wall of the camper, any thoughts on how you like them, how they are mounted?
Thanks Happy travels
Sorry it took way to long to respond. seems to be my MO :)
here is the Rotopax mount and lock i used. Simple plate mounting.
I like the rotopax tanks. they are much easier to fit places than the standard 5gal. jug. This one you are referring to in my pics is 4gal cap. I also have the 2gal tanks that can mount to the same mounts if need. I think the best feature, even better than the shape, is that the rotos do not leak or fume. They do expand a tad out of perfect shape when it gets hot, but no biggie. They are somewhat aerodynamic on a roof laying flat, they stack nicely between boxes or motos in the bed of a truck, you can slip them under gear in the back of the SUV. quite convenient in comparison to the Jug.
Im sold. Course, I'm also invested at this point ;)
zidaro
pics of the Rotopax mount and lock mechanism
Holds it tight, has not loosened with use yet. In this position- Tank is difficult enough to get to that i have no fear of it walking away, but can actually use it and fill it if i need to. Must lower window to remove lock. If i just have the non-locking screw pin installed, i can remove it with the window up.
Pacific Northwest yetti
Expedition Medic
Zidaro,
No worries Thanks for the reply!! Nothing to apologize for. That looks like a great and secure place to mount, I have started seeing an increase in them, when I saw the mounted to the front of the NS I just had to ask. They always seemed like a good idea/option. The entire rig is a good looking setup.
zidaro
Got the window mounted up nicely. Its not going to fall out or leak, thats for sure! Fabbed up a little outside shelf, decided to go with mild steel on the exterior. Plan to make a similar type shelf for the inside, wood. Still need to finish the exterior trim to make it purdy. But for now i can set cocktails on it and hook our swimsuits to dry!
MaverickTRD
man the set up looks great! especially when pulling that 4runner.
Any concerns with being over legal limits on the tundra?
zidaro
Nope. Truck seems to handle everything well. Law may not like it, but so far no issues there either :REOutShootinghunter
zidaro
added the Transferflow 46gal tank to the truck last weekend! Yahoo!!!
Now no more worrying how far I've driven and how far is still can.
Loving it
zidaro
Recent camping trip thru East side Baja! Quick but, as always, epic baja. soaked in remote hot springs, travelled along baja courses thru Laguna Salada for almost 100miles, ate insane fish tacos in Felipe, drove and camped along the beaches, tucked into remote hidden spots.
Cant wait to get south again. Lots of pics, heres a few.
Regcabguy
Oil eater.
Nice shots indeed. It's so nice to get out of the elements down there. The wind and sun can wear you out. Rims and tires look fine.
That Transferflow tank tucks right up in there. A 25 gal stock tank doesn't go far on a thirsty truck.
zidaro
Cruising Northern Death Valley, Spring '17
Eureka Dunes
Teakettle Jct.
Racetrack
Camp above Lippincott Mine Saddle
Down Lippincott into Saline
Saline
As always, DV provides!
Tatted
Question: do you air down on those trails? If so. What pressure do you run with your camper on?
zidaro
I do. All the weight really increased the chances of a puncture or slash. I drop to 30psi unless it's deep sand, then 12psi gives mega flotation.
Airing down also REALLY softens the jolt of washboard too
Henrybrowne
