Injectors may be needed....
FDM2012
With only 185k (plus many idle hours) on my rig, I hate to think that I need to do them, but until my oil hits 180, it chugs
and the injectors seem to load up and unload. Meaning that as I accelerate, they will clatter a little,
then none at all and no power, and then pretty loud for a bit, then runs fine with plenty of power.
This is more prevalent now that I am in some colder temps here in Dallas. I will probably change the
ICP sensor this week, before I head back home to Tampa.
My ICP is about 480 at idle once warmed up.
This is a good read: http://swampsdiesel.com/files/7.3LInjectorDiagnostic.pdf
Bikersmurf
Have you changed the oil in the High pressure oil Reservoir?
It may be too late, but I've read it doesn't get flushed out as well as it should and gets pretty tarry over time.
Mine has similar miles, but way more hrs... 16k+ hrs, do I'll be following along as I'm new to diesels.
IdaSHO
IDACAMPER
What are you running for oil?
And when was it last changed?
These 7.3's are pretty picky....
If you are not already, switch to 5W40 synthetic Rotella.
Ive seen it save some injectors. At minimum, it may postpone the inevitable a bit...
All of this is assuming your under valve cover harnesses and glow plugs/relay are 100%
philos
le bummer if so, I spent $4692.xx in summer 2015 to have my injectors replaced along with glow plugs, under valve cover harnesses, and a couple smaller bits.
On the plus side, I haven't plugged in the block heater once since that repair. Warm ups are much less a chore/worry now.
+1 on synthetic Rotella
FDM2012
2200 miles since last change. I did do the reservoir at that time. Rotella 15/40 and Motorcraft filter.
When running the synthetic, what are the change intervals? It sure is pricey!!
FDM2012
What were your symptoms?
kpec
I have been digging into my 7.3 lately as well, hope this helps.
Warm idle pressure should be around 550-650
Injector control pressure (ICP) sensor. Causes the engine to run, but cut in and out and really roughly throttle. Check for oil in the ICP connector, if present, ICP is bad or on the way out. You can verify better running by unplugging the ICP sensor, temporarily, to see if the issue goes away. Cost $65-$167. Part number F6TZ-9F838-A. If oil has permeated the wires, It is recommend to replace the ICP sensor pigtail as well.
These are Ford specs.
KO=KEY ON LI=LOW IDLE HI=HIGH IDLE OR=OPERATING RANGE
Inj. Control Press. (ICP / HPOP)
KO=0 LI=625.5 HI=1400-1450 OR=0-4045 psi
ICP Voltage (Volts)
KO=0.2 LI=1.0 HI=1.8 OR= .15 - 4.7 Volts
IPR Duty Cycle
KO=14.84 LI=24 HI=40.60 OR=0-50 %
makes me pretty stoked to have my gas motor!!
whole engine rebuild and all new parts surrounding it i think i was less than $3500, sans labor of course.
philos
Long warm ups in temps under 55f, some clacking.
The nut on the back of my IPR vibrated its way off, and while the magnet was still on the shaft, it was making the pressure readings go cray. It ruined injector 8 from the fluctuations I think.
So, when I put a new IPR in, it wouldn't start even. I gave up looking at it more, and towed it to a shop to deal with. Great since then.
Also, when I did the IPR, I did my own fuel bowl delete and regulated return. Cackle was greatly reduced.
djbonsu
ICP Voltage (Volts)
IPR Duty Cycle
These numbers look to be a bit high for the 7.3! I could be wrong but these numbers look to be more in-line with the 6.0 PSD and not the 7.3 PSD. At idle my ICP is between 480-510 psi depending on which mode my tuner is in.
Bikersmurf
I'm somewhat fearful of a repair bill like that... however I don't think I'd enjoy the rig as much if I was getting 10 mpg. Last highway trip (with a 9k Ambo in a snowstorm) I managed 22 mpg (US) for a 200 mile trip. Maintenance for the diesel has been minimal... if it were a gasser, it'd be on at least its third engine by now and have done way more work to it.
fielder441
I thought they looked high also! Made me go a look at my numbers and make sure I didn't have a problem. My ICP is 480 in my 100 hp tune
So far my rig weighs 4860 lbs
I usually get about 13-16 mpg across a mixed tank of gas.
