SOLD - 1995 Toyota Landcruiser, Expedition Ready, ARB Lockers, TRD Supercharger
Mlachica
TheRAMadaINN on Instagram
SOLD 1995 Toyota Landcruiser. Acquired in 2007 with about 93k miles. Currently has 168k. ​SOLD
For over a year I’ve also mulled over the price. From the examples I’ve seen, few and far in-between are any 80’s built like this one (for sale anyway) and with such low mileage. From what I’ve seen, and what I have, I’m asking $21,000. Considering all the modifications and included parts, I feel this is a fair price. See below for more details.
Drivetrain
· One of the last TRD Superchargers (installed May 2014, 150k miles) no longer available from TRD. Magnuson sells them now but at roughly $5k
· Also installed at time of SC, all OEM:
· radiator/hoses/thermostat/coolant
· Blue fan clutch
· Oem fan
· spark plugs
· Main crank seal
· Oil pump cover
· Distributor o-ring
· Power steering flush
· Power steering pump rebuild
· Drive belts
· 4.88 gear ratio
· FR/RR ARB air lockers
· Wired with OEM switch along with dash lighting for cleanest integration
· Center Diff Lock Switch
· Always used OEM parts for axle rebuild
· Power Slot Rotors/EBC green stuff pads
· OEM calipers replaced during my ownership
· 315/75R16 Toyo AT2 Extremes with matching spare, approx. 5k miles on them. Fully transferable Americas Tire Certificates
- FR axle rebuilt at 145k miles
Suspension
· Front – OME J springs with spacers
· Rear – OME 864’s
· 2.5” RADFLO shocks. Custom made per measured axle travel/weights
· FR/RR Metaltech swaybar drop brackets
· Slee Offroad extended SS braided brake lines
Protection/Recovery
· ARB Front Bumper with Lightforce Lights
· Warm M10000 winch
  • Amsteel synthetic winchline
  • Safety thimble
  • Delrin rollers
· Hanna Quality Sliders with Cat protection
· Slee Offroad T-case skid
· 4x4labs rear bumper with vision x LED flood lights and Hi Lift Jack
- Sides have been Line-X'd after removal of the fender flares
Communications
· Yaesu FT-7900R 2m/440
· Comet nmo antenna
· Cobra 75WXST compact/remote mount CB radio
· Panavise dash mount with ram ball
  • You can add a RAM arm and cradle for whatever device, I used it to hold my phone or ipad.
Expedition Gear
· African Outback lockable drawer system with fridge slide, imported from South Africa via Slee Offroad
· African Outback 19 gallon water tank (mounts on drawers, against rear seats)
· FrontRunner Outfitters Roof Rack
· Fiamma F35pro Awning
· Helton Hot water heat exchanger, plumbed to quick disconnects on front bumper
  • Shower pump/head also included (I think it’s a flojet pump)
Electrical
· Dual Group 31 AGM deep cycle batteries in OEM locations
· Perfect switch, low impedance battery isolator. Solid state, no solenoids.
· 150a Alternator OEM Toyota (I will include a spare)
· Carmanah/GoPower Solar controller, I think it’s rated for 25amps. I’m keeping the panel.
· Blue Sea fuse block in engine bay/rear cubby
· Additional 12v outlets in center console/rear cubby
· Tekonsha Prodigy P2 Brake Controller
(Fridge and gun stuff not included :). Illuminated with LED light strip installed on rear hatch)
Included but not installed
· Toyota Aux fuel tank and mounting straps (approx. 15 gallon capacity)
· Dual filler neck
· Fuel sensor
· Overhead console with fuel level gauge
· Shortened sun visor to accommodate overhead console
· Ram mount for small laptop
· 3[SUP]rd[/SUP] row seats
· Various lightforce light filters
Know issues
· It’s a 1995 so it shows it’s age accordingly
· The clear coat is fading on the hood/rear quarter panels
· The rear hatch power door lock doesn’t always work (still useable with a key)
· The power seats should be addressed, the driver still works, the passenger needs the gears replaced. (I will include the needed parts to repair both seats)
- The antenna doesn't go up/down
· If you don’t warm up the engine to about a little over 100*F (I use a scan gauge to monitor) there’s a chance it’ll throw a check engine light (either p401 or 402, I don’t remember) it has to do with the EGR system. I warm it up every time and haven’t had the code for well over a year. The scan gauge indicates the ECU is ready. It passed smog two years ago, I’m confident it’ll pass now as my registration is due by February.
· The rear swingout needs one of the stops relocated for the latch to properly toggle. The latch still closes, I just tie a small rope to keep the latch from opening. Luke at 4x4 Labs said he’d take care of it but I haven’t taken the time to mail him the swing arm.
I’ve held this TLC near and dear to my heart, and always will. I’ve talked about selling it for over a year but never had the courage to sit down and actually do it. I wouldn’t hesitate to take it anywhere around the world as parts are widely available and it’s never let me down. My wife and I took our 3 boys on a 9 day eastern sierra camping trip this last summer and I’d do it again in a heartbeat. In 2014 I drove it 15 hours straight from Colorado to California with the family in tow and not a single complaint.
Mlachica
The cable around the snorkel is for the solar panel and it plugs into the front bumper. It was a temporary deal that became semi permanent. I'll be keeping the solar panel so there won't be any cable. The plug will still be in the bumper to plug in your choice of solar panel.
blupaddler
Conspirator
Mark... I've been there done that, and completely understand your decision. I still miss my 80 to this day.
Folks, I'm not active on here much anymore. But I've been around since the beginning and have traveled with Mark a few times. Mark takes excellent care of his stuff, and if anyone is looking for a QUALITY 80. One that's ready to go anywhere now, this is it. Buy this and have no regrets, and people will envy you as well.
GWLS
Mlachica
Thanks guys!
ya for sure Jeff! The pleasure was mine. Hopefully by early summer my new rig will be ready for adventure. I'll hit you up. If you have any questions about the rig, feel free to contact me
gp01
