NC06LJ
Decided since I'm not a smoker :ylsmoke: and my wife is always searching for outlets to charge devices (phone, GoPro, iPads, etc.) I'd add a new USB port.
After a quick search on Amazon I came up with the Dual Port USB outlet from Cilena (pic below). Shipping was quick and at $14.99 I think its a solid addition.
The port for the cig lighter was just a bit too small for the USB, but a Dremel made quick work of widening the opening.
USB than slid home and is held in place by a simple jam nut
Kit comes with the spade connectors, so a wire stripper/crimper or soldering set up is all you need to install
Once your accessories are turned on via the key the outer ring on the outlet lights up blue for evening plug in ease
I'm pleased with the fit and finish and will do some recharge time tests this weekend
