What To Look For Gen 3
arb098
Hey guys! If all goes well, I'm fixing to pull the trigger on an '01 Montero Limited. I'm heading out to look at it later today, but I'm wondering if there is anything on these Monteros I should look out for besides the typical drips and slips. So, y'all got any advice for a first time Montero buyer?
Tliska10
Maintenance records!!!!
Timing belt/water pump. Hydraulic timing tensioner.
brake accumulator
All these went out in me when I got mine, and I still have little headache with it lol but dam do I live this truck
I would honestly go for a 2003+ 3.8 and traction control.
I have a 2002 which I live and got a great deal in since all those problems, and I only have 108k on mine
arb098
brake accumulator
I'd kill for a 2003+, but I'm getting a hell of a deal on this one. It's kinda high miled at 170k, but I'm getting it for $1500. If I show up and it looks like immortal ****e and is running like a 1 legged, 3 toed bull, then I'll pass and keep on looking. Lol
Sabre
Overlanding Nurse
That's a great deal on an '01 LTD if it's in decent shape. I know that folks go on and on about the larger engines in the later models, but honestly there's just not that much difference.
My '01 is a really great rig, and I have no plans to replace it. Any rig that age will need the usual stuff: brakes, shocks, bushings, possibly bearings, ball joints, etc. Specific to the Monty, the timing belt, cam seals, oxygen sensors, properly functioning lights and wheel behavior for the various 4wd modes. Assume you'll be changing diff and transfer case fluids and doing a full transmission service.
Keep us updated!
Fergie
Cycle through the 4wd to make sure the t-case switches are operating...if not, it may get cheaper.
CV boots and all that stuff that has been mentioned before.
jhill15
Drive it for more than 20 miles without turning it off to make sure you don't have flashing 4wd lights!!!
Sent from my LG-H900 using Tapatalk
alex9528
Another thing that I would not consider are the 01 and 02 XLS models. They are 4 speed and do not have center locking diffs and no activ-trak-4wd system (only limited models have this). 03s and up have all the same traction systems which are desirable.
clmrt
I'm pretty sure they have locking center diffs, even in 4-hi. There is no open center diff in the 4-speed equipped G3. The 01-02 XLS was available with the rear LSD for 2-hi, and 4-hi locks the center. 4-lo does what it does. I prefer this over the Limited style, for my driving habits (95% tarmac, 4% deep snow, 1% non-technical offroad.) That may sound strange, some thinking and open 4-hi center for full-time AWD is best for tarmac, but with Mitsu's LSD in the rear and an educated right foot, there's little reason for AWD on pavement. And if the road is too treacherous for 2wd, 4-hi is right there. In when you need it, out when you don't, on you go. Having the Limited's electronic wizardry and all it's sensors in between the cabin and the road is a detriment, even though when it works, it works. But I like the analog feel and performance of the mechanical linkage.
That said, if I were buying a Montero today, I'd buy a 2002 XLS with all NTSB recalls done, clean records, one owner, well maintained with docs. $4000 or less, there should be 2-5 around the country at any time.
Inyo_man
Don't piss down my back and tell me it's raining.
That sounds like a great deal...
Hopefully the owner has service records.
I actually prefer the early Gen III with the LSD, rather than traction controlled...I just wish they had the 3.8L.
