GREAT WHITE BUFFALO (2016 Carli Cummins build)
JESSE A
Looking for some opinions on a couple things.
1. Looking into a decked drawer system for the truck, pros/cons, quality? Will a skottle fit in the drawer? Is there anything other system that is a better value?
2. Rear coil springs. With the flippac, tools, gear firewood the rear squats too much (almost rides on bump). Im thinking about going back to the stock springs,see how they work. Any suggestions? Company/custom springs?
Instagram @bluedog_co
ttengineer
Ya some long travel air bags would be nice, timbrens?
I don't think Timbrens would give you the desired ride. They are more of a quick fix that that you add and remove as needed. I think airbags with the daystar cradles would be the best option but are far more costly.
JESSE A
Cool, i dont mind spending the money and doing it right. I know carli sells long travel air bags, but not for my truck. I definitely would not want to limit the travel.
ttengineer
Call them. I know they are working on something for the Ram.
uscg2008
about firestone riderite airbags and daystar lower cups. I had that set up on my Tacoma and really liked the fact that I could still flex the axle out.
And with them wired up
JESSE A
Those look nice, im debating just putting the stock rear Springs back in. What do you guys think will they flex and ride smooth enough with the extra weight.
str8t six
kelderman makes a kit to replace the rear coil springs with air bags. i would think they would atleast have the same amount of travel as the stock springs.
https://kelderman.com/shop/2014-ram-2500-2-stage-rear-air-suspension-coil-replacement
JESSE A
Carli rear springs are for sale 1 inch lift, softer nicer ride than stock. 2016 2500 ram. 250.00 obo
Sent from my SM-N920T using Tapatalk
JESSE A
Finally got some stiffer springs from Carli suspension they should work great.
project13support
