NEW RIG: 2012 F-150 FX4
D45
I cannot say enough about the DT Adjustable Lockable Receiver............simply love it. Easy to adjust, rated very well, and is SECURE
Also love this tool kit..........portable, made VERY WELL, and somewhat cheap (bargain cave at Cabelas for $70)
Self contained in a very heavy duty carrying bag................Hi-Lift Handle All
Telescoping implement handle, Full-sized shovel head, Full-sized sledge hammer head, Full-sized axe head, Full-sized pick-axe head
D45
The new PIAA light switch arrived and it was a fast, easy install
Just cut three wires off the old switch and three wires off the PIAA harness
Solder and install........the double sided tape holds the PIAA switch nicely in place without having to drill a huge hole in the dash panel
Much nice switch now and am loving the LED bar
Time to install the Corsa resonator delete now.........hopefully tonight
adrstout
Clean install on that light bar. Just did a single row behind the grille myself. I'm not a huge fan of light bars aesthetically but they are effective so I like low profile mounting options. Been quietly following your build for a while and really like it.
20170325_174624.jpgs
D45
Stock resonator is OUT and the Corsa delete pipe is IN
Removal went smooth, broke off the two bolts on the flange end the broke the bolt on the clamp in
Heat from a torch loosened up the clamp up fast and a large pipe wrench helped to turn and loosen it
Total install time was an hour
Nice rumble at idle.........sounds pretty damn good for a V6. I will drive it tomorrow and see how it does on the road
gtbensley
To answer your question on pirate....run a catch can. It will significantly cut down on carbon buildup in your engine and help to keep issues away down the road. As far as what one in particular, can't really give much insight.
D45
Well the dealer can't find the constant clunk, which only happens on acceleration
They can duplicate it, but cannot fix it
Pathetic......I am going to try to tighten the differential mounting bolts ( which on some Raptor trucks are loose) and also try swapping in the Raptor V8 trans mount, which they claim to help
If not, I am going to have the slip joints on the rear driveshaft greased and then look into new front shocks/struts
D45
..........and now, a LOUD creaking noise is coming from the driver side wheel well area when the suspension moves
littlevulture
I get a loud clunking from that area in my 2008 F-150. From my research I think it's the sway bar but I haven't been able to disconnect it yet to verify. I'd give that a check.
D45
The newer creaking noise happens when I turn the steering back and forth.......like a bushing is dry somewhere
The old clunking noise happens when I accelerate........like something is loose
Very annoying for a truck that stickered for $52k
D45
I drove some truck over the past weeks, all way too expensive for me..........but just to get a feel on a the used truck market
Dodge Ram 1500 4x4, with the 5.7L Hemi. Power was nice, just seemed it was all higher RPMs. Truck felt "cheap"
Chevy 1500 4x4 with the 5.3L V8.........pathetic low end power. Smooth motor and smooth acceleration though
I drove my friends loaded out $60k GMC 1500 with the 6.2L V8..........I loved it, power power power
My 3.5L Eco definitely has more low end power and a stronger off the line feel..........interior is by far, the nicest
Just an FYI observation
mizedog
Thanks for this. Did you feel the Ecoboost is in the same league as the other V8s?
Sent from my SAMSUNG-SM-N900A using Tapatalk
D45
Yes, definitely feel the 3.5L Eco holds up to most of the V8s in the class
The 3.5L has power down low, something most lack.....especially with the low RPM band torque
The 6.2L Chevy motor is a beast though, I am very in love with in
stingray1300
The real beauty of the EcoBoost, is that most V8s achieve maximum torque at around 5,000 rpms +/-, while the EB's maximum torque is achieved at around 2,500 rpms. Which would you choose to "off-road" with? And, for a mere $300+, you can add another 65-85 horsepower and another 50-70 ft lbs of torque (with a tune... even a boxed one).
Have a look at www.tfltruck.com (The Fast Lane Trucks) for all kinds of compare testing these guys do, especially towing tests on the Ike Gauntlet in Colorado. And there's also pickuptrucks.com.
D45
Yup.....low power band power makes it a good platform
Just for comparison, here are the available motors in a Chevy 1500 Silverado:
4.3L V6
285 horsepower at 5,300 RPM
305 lb.-ft. of torque at 3,900 RPM
5.3L V8
355 horsepower at 5,600 RPM
383 lb.-ft. of torque at 4,100 RPM
6.2L V8
420 horsepower at 5,600 RPM
460 lb.-ft. of torque at 4,100 RPM
V45W_Proto2.5
