2000 Ford 7.3L Motovan build (225's build cont'd)
another_mike
That's great!
Really? that's great? he just drained 30 gallons of diesel/gas onto a parking lot...
Im still recovering from physical injuries after after highsiding a motorcycle on a roadway cause someone allowed diesel to cover the roadway starting mid corner on a turn. Draining diesel on a road is anything but "great". The police tried to track the spill to find the person that caused it, since it caused a crash with injuries, but the spill had stopped before the vehicle that caused it.
Corneilius
Yeah thats not cool. Any shops would have oil disposal drums, most auto parts stores too. Seems like 6 Five gallon gas cans would have worked.
225
Village Idiot
Oil Change Day.
Today was oil change day. Not sure when the last one was done, but I'm positive it needed it. I've done put 3k on her already. I have a new fuel filter, it will go in in a couple of days.
The air filters were shot:
Can't break old habits. We do this on the boat I work on to keep track:
And the best tool in the world, a oil drain plug holder. Break the bolt, then use this nifty bastard to stop you from getting hot oil down your arm.
Next couple of days, I'll be stripping the interior and figuring out how to build new seat mounts.
225
Village Idiot
Started working on the interior.
Ripped the rubber floors out. What a mess!
All clean!
The front was just as bad.
Buffed, used rust inhibitor, primed and painted all the rust spots.
Wood sub-floor in:
Reflctix in the front:
New outdoor carpet in:
Vinyl flooring in:
Threshold plate between the two:
New center console and head unit with backup camera:
Now I need to trim the exposed plywood with aluminum and install the L-Track and the new seats!
225
Village Idiot
I drove 12 hours back to work...
Why I have trust issues. Same color as E85 handle.
Only one van in the whole junk yard. At least I was able to get a new arm rest I needed.
Hammock pit stop:
225
Village Idiot
I've been kicking the idea around of adding power windows and door locks. After looking and planning around, I think I'm going to do it. I'm not going to try to wire it into a harness that isn't there. And I want keyless entry, which isn't possible even if I had the power harness in the van.
I'm still planning, but here is the general idea.
My windows will use OEM window motor / regulators, wired to a ACC power source.
I ordered 2 of these:
Once I figure out the up/down on the door switch, it should work.
Then for the door locks, I'm going with a aftermarket keyless entry system with OEM door actuators.
I already bought some door switches off eBay:
I'm looking for electric door panels too. Just need to go boneyard hunting.
While I'm at it, I'm going to fiberglass some component speakers in the door and cover up the original speaker grilles. And then spray the whole door panel with OEM interior paint.
My first order of business is building the seat mounts once I get back in from offshore. Next will be the doors and building a gas air compressor.
B^2
All clean!
Wood sub-floor in:
Vinyl flooring in:
What did you use to clean the floors/how long did it take?
225
Village Idiot
I used Dawn dish soap and a water hose. It took longer to pull everything out than it did to wash it.
Pulling the old rubber floor, washing it, drying it with a fan, and priming and painting took a half a day.
djbonsu
The boneyard is your best bet or Craiglist. If you find some power doors, you may get lucky and be able to plug and play! My power windows were plug and play via my OEM harness but my locks werent so i have to make a circuit for it to work properly as a ground wire ot two was missing from my OEM harness. Good luck!
Kallan
