Not So Subtle E350 Shuttle - 100% Satisfaction Guaranteed
brianjwilson
Some sort of lost...
Thanks, it's fun to shoot the process. Build threads are a place for me to experiment with my photos without having to please a client. Like personal work. I enjoy it.
I am at once super excited and also a bit nervous. It is going to be so much bigger! Like way bigger. Like 9" taller which on paper sounds like no big deal but when you actually walk up to and get into a van like this - it's ginormous.
Next week will be busy. I'd love to meet if you stop by. The new axle is supposed to show up on Wednesday. Fingers crossed...
Gregor
Oh yeah it will be bigger alright! I was a almost surprised after we got mine together. I won't be back in town until the 10th so I'd suspect you'll be up and running by then. If not I'll try to swing in when you're around.
Bbasso
Expedition goofball
I would prefer to either build an A-pillar pod or find/build a dash pod.
Here's mine...
mr_magicfingers
Great write up Gregor. Like you, I'm a bike guy who doesn't know much about cars/trucks but I'm lucky to have a great, reliable and affordable garage up the road from me where I take mine for servicing and any needed work. The bikes get done in the barn by me though I'm nowhere remotely near your mechanical skill level, you're stuff is inspiring and reading your threads is a great mechanical education.
Loving the photos, I always sit and look at them and try to figure out how you've taken them, how you've exposed them etc. It's a great learning process. Technically, my work makes me a professional photographer, as for part of my job I get paid to take photos, but they're technical stuff rather than artistic and, well, artistic is something you really couldn't call me.
I'm guessing you're using Sony A7's? I had a play with a couple of the high end models as one of our on-set photographers (I'm in the film business) had switched to them from his Canons as the A7's were silent which meant he could ditch the sound blimps and have much smaller rigs to crawl around set with.
sakurama
Thanks! And yes, on the Sonys. I picked up the Sony A9 which has been a big improvement over the A7 which is/was amazing but quirky and not all that fast. The A9 is lightning fast and a bit more intuitive so I'm liking it way better. I like the freedom of build threads - they're a chance to play around for me - it's like personal work. It's also been really fun to learn about the underpinnings of the van. It will help when I assemble the on board tool kit for the van.
Gregor
Jsweezy
Great photos! That transmission lift sure looks handy. MG man handled the transfer case on my van while I threaded a couple bolts. That looks waaaaay better. Josh's shop would spoil anyone who is used to working on things in the driveway. After working on my van at his place, the LAST thing I want to do is crawl around on the ground in my sloped driveway and work on it.
I'm sure you'll love the whole setup. I'll have to stop in and check it our again, if it's still around when I'm back from work.
Thanks for the kind words! I'm just happy to help and make some friends along the way.
sakurama
We're still waiting on the replacement front axle which is supposed to show up on Wednesday but we managed a bit more more work on the other end that I can catch up on now.
Now that is a torque wench! Wrench! Sorry, yes, wrench... So easy to get them mixed up. MG mentioned what it was for and now I've forgotten but maybe Josh or MG can remind me.
Just to be sure MG measures up the new Sterling axle. Bigger brakes and a locking rear diff are the reasons I decided to go with it and it also happened to match the ratio of the front axle we'd found at 3.73 but I don't know that the new front is the same although I'm sure MG took that into consideration.
Before the axle can be fitted the rear springs are installed. Josh is preparing the custom U-bolts and plates to test fit the axle. It's nice to see how detail oriented Josh is about cleaning and painting any exposed steel. I wish I could go in and clean up the rust on the frame but it's pretty minor surface rust and I can deal with that when I install the flares down the road.
Probably the most difficult thing for me to decide on was the wheels and tires. I knew that life would be easier if I went with 33's and a 4" lift but if you're going to drop $$$ into a 4x4 van you really don't want to have regrets. I would spend hours looking at vans until I could see a photo and tell you the tire size instantly. 35's just looked right and I knew those stock Ford rims with 33's would disappoint me. I also loved the look of the aggressive mud tires but I knew that they wouldn't be suited to the terrain we plan on visiting or to the fact that the van will nonetheless live mostly on pavement. So the BF Goodrich A/T KO2's are a standard. I've owned a few sets before and they were always stellar and lasted a long time. Most of what we're going to do is driving on the beach and in the mountains in snow. These tires will do that very well based on previous experience.
Anyway, the wheels and tires I chose are now put on the rear axle so we can set that in for positioning.
The van is lifted up to clear the wheels and the axle is rolled into place.
The previous spring perches were ground off and new ones made and placed under the springs. It seems a bit crazy to me that this is basically the same suspension as was used in covered wagons. It's either a brilliantly simple idea that has stood the test of time or it's a hopelessly primitive solution that's never gotten better. Or maybe it's neither. Not sure.
I'm torn on if the letters should be white in or out. I guess I'll try this for now. Regardless that is a serious axle and *** end.
We need to get the front axle before we can lower the van's full weight onto the axle and set the angle of the driveshaft. Right now the spring perches aren't locked in so that we can "aim" the rear diff to the transfer case in a straight line. That extends the life of your u-joints. It also looks like the wheel is too far forward but the wheel moves in an arc from the transfer case so it will go farther back as it compresses.
At this point I'm a bit incredulous as to how tall the van is. A million photos on the internet does not convey the height of this van at the moment. Josh laughs and says it will actually be this tall and MG keeps saying, "No, it will settle a few inches" and I am just excited and nervous not sure either way. One thing for sure is that after a year of thinking about this it's actually happening. That's pretty exciting!
Gregor
brianjwilson
The big *** torque wrench is likely for the track bar bolts. It is very important to get those suckers properly torqued.
thats one of those torque wrenches thats when ya go onto the tool truck, you gotta be like "boss says he's got the biggest torque wrench, but i want one bigger"
its like those super mega 60" pry bars from 1" square steel, i mean, its not a mechanics re enactment of the highlander.
ClubWagon
I've got BFGs with white letters out on both of my vans. I've always liked that look better when you have a big sidewall. The van is looking great by the way! Coming along nicely. 👍🏼
Petersmithinak
